91 Camaro RS 305 tbi to 350 tbi swap
Old Aug 9, 2012 | 09:42 PM
Knuckl3s's Avatar
Car: 91 camaro rs
Engine: 350 tbi. Rv cam. Edelbrock headers
Transmission: stage 3 700raptor 2400 stall
Axle/Gears: 3.42 posi+disc brakes
Hi guys i have a 91 camaro rs with a 305 tbi. I want to swap to a 350 tbi out of an 88 gmc sierra 4wd. The camaro has edelbrock emissions headers(all the emmisions stuff is capped off) it has straight 2.5 inch exhaust and h pipe at the rear. It has a 746' ecm. 700r4 overdrive with a shift kit. I was wondering if i should use the tbi that is already on the 350. I want to do the ultimate tbi mods either way. What else do i need to get the engine to run how it should? Thanks guys any info helps.
Old Aug 10, 2012 | 11:16 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, you should use the TBI already on the 350. I believe the computer as well (better to ask about that on the TBI forum).
Your exhaust should be 3" minimum after the two sides join. Or, are you saying it has 2.5" duals now? Not sure what you mean.
Old Aug 10, 2012 | 02:14 PM
Knuckl3s's Avatar
Car: 91 camaro rs
Re: 91 Camaro RS 305 tbi to 350 tbi swap
It has 1 2.5" pipe from headers to rear then it has the dual tips coming out.
Old Aug 13, 2012 | 06:35 PM
five7kid's Avatar
Okay, that's what I thought, but wanted to be sure.
3" would be much better.
Old Aug 13, 2012 | 07:08 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Yes you must let her breath.
Old Aug 13, 2012 | 08:58 PM
Knuckl3s's Avatar
Car: 91 camaro rs
Ok, so. I got the engine in it has an rv cam since the engine was from a truck. When i first start it up, warm or cold. It has like this wandering idle. What you think that is? Oh and it. Has a 2000 rpm stall torque converter. Sometimes it dies wjen i go to put it in gear also.
Old Aug 13, 2012 | 09:00 PM
Knuckl3s's Avatar
Car: 91 camaro rs
Oh, and i dont have the money to put a three inch exhaust on it. Starting uti in glendale Heights Illinois on Monday
MustangBeater20
Oct 29, 2022 09:20 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
