Cam selection with vortec heads help
Subscribe
Aug 14, 2012 | 11:21 PM
The 355 I swapped in is pretty decent right now( compared to the 140 hp 305 I had in) , dynoed it at my school at around 270 ish hp.
I'm eager to swap the heads and cam. Would like to get the engine producing over at least 310 hp
Any advice on the lift and duration of the cam with vortec heads, that would be suitable for only street use?
I will be upgrading the springs and rocker arms to match the cam, for the record.
Reply 0
Aug 15, 2012 | 02:35 AM
Re: Cam selection with vortec heads help
Quote: I will be upgrading the springs and rocker arms to match the cam, for the record.
You are aware of the .480" lift limitation on stock Vortec heads?
Machining of head or beehive springs required for greater lift
http://forums.corvetteforum.com/1554844521-post11.html
http://forums.corvetteforum.com/1554840631-post9.html
Using cheap LSX springs
https://www.thirdgen.org/forums/post...681-post1.html
http://www.chevyhiperformance.com/howto/97458/
Reply 0
Subscribe
