Difference between 305 and 350?
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
Ok I know basically everything is the same. Same stroke just bigger pistons. What is the difference on the outside of the engine. Like are the engine mounts the same? Same position? Are the heads the same? Will my exhaust fit or will I have to modify it? Stuff like that. Thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Difference between 305 and 350?
Externally, all SBC blocks are the same size. Looking at one under the hood of a car, and you won't know if it was a 265 or a 400.
Car: 1985 camaro iroc z-28
Engine: 5.7L
i like to know a trick to find out whats under the hood of my 85 camaro. i was told a mild build 350 tpi. but i think i was tricked and is just a stock 305 tpi.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the casting numbers. There are no other ways to tell.
Car: 87 IROC L98
Casting numbers are the best way. The newer blocks also have 5.0L and 5.7L cast into them.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
And let us know what you find out and if you were scammed and by who.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Sanjay
Aug 12, 2015 03:41 PM
