350 swap
Old Sep 27, 2012 | 08:34 PM
Colby Contois's Avatar
350 swap
I know there have been a million and one threads about 350 swaps, I'm not quite sure where to look for my particular issue.
First, I have a 1984 Camaro with a 350 in it currently, this engine has a 2 peice rear main seal, as a NWC Borg Warner T5 with a 6 bolt 153 tooth flywheel. Currently I am assembling another 350 that came out of a 1998 Chevy Express Van (3500), this motor has a 1 piece rear main seal, and was mated to an automatic 460LE trans. Though I do not have the engine in front of me, I believe that the crankshaft output has a 7 bolt pattern, I am wondering what I should do about getting the correct clutch for this engine? Will my existing clutch work? Any information is greatly appreciated. I am aware I may have to address a pilot bushing issue, if the crank does not have provisions for a pilot bearing what options do I have? I have yet to take the crank out, nor have I inspected it, but these issues came to mind and am wondering how they can be resolved.
Thanks for your replies,
Colby
Old Sep 27, 2012 | 09:00 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 swap
Late SBC crank also has 6 bolts but in a different bolt pattern to suit the 1 pce RMS ;prevents people putting the wrong balance flywheel / flexplate on the wrong engine
First up you will need to find a 153 tooth flywheel to suit a 1 pce RMS crank
http://www.summitracing.com/search/P.../?Ns=Price|Asc
and most likely your existing clutch work on that just like on your present one
Old Sep 27, 2012 | 09:21 PM
89JunkerRS's Avatar
Car: '89 Camaro RS
Axle/Gears: 3.42, Open
Re: 350 swap
a standard flywheel, and clutch set, from a later camaro with one piece RMS should work just fine. your clutch set may actually work, but if I remember correctly, they slightly differ in diameter.
Old Sep 30, 2012 | 08:48 AM
Re: 350 swap
The clutches are identical. No difference whatsoever, in diameter or anything else, between 1-pc & 2-pc RMS applications.
Just get a flywheel for a 86-up 305 TPI (Camaro/Firebird w VIN code F). Nothing fancy, special, or unusual required at any time.
Don't forget to put a pilot bearing or bushing in the crank.
Old Sep 30, 2012 | 10:10 AM
89JunkerRS's Avatar
Car: '89 Camaro RS
Re: 350 swap
I really didn't see why they would be any different, but for some reason I thought the autozone website showed they were, seems like it was just a fraction of a difference though, but its good to know they interchange
a few months ago I helped my brother do the opposite conversion in his 89 rs, when he swapped his car over to 5 speed it had an older 350 with the 2 piece rms, but the trans and everything was out of another 89 rs, and a flywheel for an older camaro worked like a charm, but I wasn't sure on the clutch, becuase he just bought a new one while it was apart
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
