Another balancing question....
Old Oct 8, 2012 | 10:46 PM
xSAABSTORYx's Avatar
Car: 88 Camaro IROC-Z
Engine: 305 TBI...for now
Transmission: M5
Axle/Gears: Not sure
OK, so I know this topic has been brought up a lot but I'm still a bit cornfused, so here goes.
I've got an '88 Camaro IROC 305 TBI that is smoking bad, most likely fried rings so I decide to go to a 350 TBI out of a 92 Suburban that has a bad head gasket (found water in cylinders 5 and 7). So here is my conundrum, the suburban was running a 700r4 trans, and my Camaro is running an M5. The flexplate out of the suburban looks like it is weighted so does this mean it was an externally balanced crank? The main thing I'm driving at here is can I simply swap the flywheel off of my 305 and still use the harmonic balancer off of the 350 or do I need to also use the balancer off of the 305?
Any help would be appreciated, this is my first engine rebuild.
Old Oct 9, 2012 | 12:51 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Another balancing question....
The flexplate out of the suburban looks like it is weighted so does this mean it was an externally balanced crank?.
https://www.thirdgen.org/forums/post...461-post4.html
can I simply swap the flywheel off of my 305 and still use the harmonic balancer off of the 350 or do I need to also use the balancer off of the 305?.
So long as your '88 305 is the original 1 pce RMS engine that came in the car from the factory
then both the flywheel and balancer will swap on to a 92 1 pce RMS engine.
Both have neutral balance balancers ( truck may be larger ) so you can use which ever is best
Old Oct 9, 2012 | 08:39 PM
Transmission: M5
Thank you very much for the reply vette. That post helped tremendously as I was thinking of it in terms of it being balanced inside of the rms or "external" to the crankcase.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
