305 tbi to 350 carb swap
Car: 91 Camaro RS
Engine: 1968 Corvette 327 SBC
Transmission: TH350 Long Tail Swap Coming
having problems with my car staying running in gear.
converted car to carb setup will stall in gear everytime no matter how good the car may be running
its a 350 small block with these mods
mods-
nostalgia 30+30- cam half inch lift
comp cam roller rockers
edelbrock 1406 600 cfm carb
heads never looked into came off of a chevy crate 350 block
hei distributor setup with vacuum advance and switch giving power to the coil
fuel pump ran on switch also
basically deleted the computer setup at this point and have no idea whats wrong
really need help, idk if its timing, fuel, vacuum, im just lost
someone help please
mods-
someone help please
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 305 tbi to 350 carb swap
Engine may appear to idle fine with bad timing but the moment the load comes on ( in gear ) ,it will stall
