Motor mount interchange
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Are the block side of the motor mounts universal? Because Iv got a set of mounts on there from the truck that my motor came out of, it was a 96 Chevy suburban 2500, should I be okay running these?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Motor mount interchange
You will need ThirdGen Clamshells and motor mounts. The clamshells are NOT the same on each side.
Engine: L31 350
The clamshell mounts I have looks like that?
Engine: L31 350
lets note on this, older truck mounts WILL work, i used the ones off my 96 truck motor and the motor set in perfectly
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
