sensor location?
Old Oct 16, 2012 | 09:57 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
sensor location?
can anyone tell me where the oil pressure sensors go? iv only got 1 hole above my oil filter and on my old v6 i had to holes, one for the gauge and one for the fuel pump, i figured the gauge one went above the oil filter, and then the fuel pump would go down the side of the block towards the center? the coolent gauge sensor goes in the driver side head and the ecm temp sensor goes in the intake? does this sensor control the fan from the ecm? or could the gauge one do this aswell? and i cant find the white wire for the tach for my HEI distributer, i found one next to the power wire that is black with a white tracer, could this be it aswell?
Old Oct 16, 2012 | 10:16 PM
christine91's Avatar
Car: 1991 Z28 Camaro
Engine: Forged 346
Transmission: T56 stage 2 Tick
Axle/Gears: 4th gen 10 bolt/ motive 4:10s
Re: sensor location?
Are u using stock 87 wiring or some other like tbi harness or tpi? If so what year? Sbc should have a hole next to the distributor hole for a oil sensor but that may have just been for 86-up with F.I and center bolt heads. Depending on the wiring the fan will have a relay which will have a switched on controlled by the temp sensor on the head. But that is also going from memory on a v8 harness not the v6 stuff. I assume it is similar. As for tach signal just look up the pinout for your year and engine.
Old Oct 16, 2012 | 10:22 PM
Engine: L31 350
im using the stock v6 harness that came with my car, im using the edelbrock 2116 proformer intake for my vortec heads and it doesnt have a hole near the distributer for any sensor.
Old Oct 17, 2012 | 09:10 PM
Engine: L31 350
Bumb, come on guys I need help on this issue
Old Oct 17, 2012 | 09:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's no oil in the intake, the hole is in the block.
Old Oct 17, 2012 | 09:53 PM
Engine: L31 350
thats what i said lol, where do they go? i know one has to go above the oil filter, i figured that would be the sensor for the gauge, but what about my fuel pump oil pressure sensor?
Old Oct 17, 2012 | 11:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Doesn't matter so long as both are into the oil galleries.Corvettes have both at top in the block
Do both units have the same thread size?
The hole above the filter on a SBC is usually larger (1/4" NPT ) while the one at back of the block is 1/8" so that may dictate which one goes where
Since you have a carb now how are you wiring the fuel pump?
If not running pump through the OP switch then you don't need it ; just plug the hole
Old Oct 18, 2012 | 05:28 AM
Engine: L31 350
I believe the threads are the same size on both opsu, but as far as the fuel pump goes I was running it through my 2 prong opsu and leaving my ECM in place.
Old Oct 18, 2012 | 05:51 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You don't need the ECU with a carb.
Wire the pump directly to the OP switch ( which is not connected to the computer anyway )
As soon as you crank the engine over ,the pump will run and stay running so long as engine has oil pressure
Exactly the same as the stock circuit diagram shown below but without the pump relay
( which is controlled by the computer ) in place
Nick McCardle
Sep 10, 2015 08:36 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
willyjoejr
Sep 3, 2015 09:26 AM
tonys91rs
Sep 2, 2015 07:07 PM
