V6 to v8 tip swap
Old Oct 19, 2012 | 01:29 AM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
V6 to v8 tip swap
Bought a 91 v6 vert would like to swap to a v8 tip. Just wondering if anybody has done this. I have all the parts but not sure if it would be a hard swap. Any feed back would be great thanks!
Old Oct 19, 2012 | 06:53 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: V6 to v8 tip swap
Look at the top of this engine swap page
V6 to V8 Swap - READ BEFORE POSTING NEW!
https://www.thirdgen.org/forums/engi...swap-read.html
Old Oct 19, 2012 | 06:58 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
If you get a complete engine/trans from a 90-92 with harness in tact, it will be very straightforward.
Old Oct 20, 2012 | 07:58 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i literally just did this swap this week, the hardest part are the motor mounts because of the angles and where the bolts and nuts are for them, after that and you get your fresh mounts in, the v8 slides right in all pretty as can be. but i also put a carbed motor in aswell so that might have something to do with it.
Old Oct 20, 2012 | 12:40 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Just as easy if he's starting with a setup from a 90-92, the V6 and TPI cars used the same chassis harness, its a direct plug in, wiring wise.
As you said swapping over the engine mounts is the biggest issue, and realistically unless yours were just replaced with the V6, its probably time to replace them, may as well get it done while gaining a lot of power anyway.
Ghettobird52
Apr 21, 2020 08:44 PM
Warlocksirix
Sep 3, 2015 12:26 PM
theshackle
Aug 22, 2015 06:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
Hello, Michael
Aug 20, 2015 03:19 PM
