V6 and v8 alternators different?
Old Oct 28, 2012 | 09:16 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Are there differences in the size between the v6 and v8 alternators on our cars? I'm trying to use the alternator off my old 2.8 motor as I just had it rebuilt about a year ago and I know it's in good working condition but it seems like the pulley is too short and won't live up correctly with my water pump pulley and crank pulley
Old Oct 28, 2012 | 09:48 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: V6 and v8 alternators different?
basicly 3 different physical sizes of alternator came on thirdgens,'85-86 v6 was one of the engines that came with the largest size-17si type,85-86 TPI also came with the 17si.I think v6 belt is different from v8,but pulley position is the same.What brackets are you using on the v8 engine?
Old Oct 28, 2012 | 10:20 PM
Engine: L31 350
v belt brackets off an 87 firebird 305 tpi
Old Oct 28, 2012 | 11:51 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
with correct pulley you should be able to use the '86 v6 alternator with the '87 v8 setup-87 used the smaller cs130 alternator,so you will need to modify the upper alternator bracket some or use the upper bracket meant for 85-86 TPI(will also need modified a little)or the upper bracket from 82-83 with 70 or 85 amp 15si(CFI will need modified,carb version likely bolt on)probably will need the pivot bolt spacer from 15 or 17si v8 too,but that part can be replicated or substitute used if needed.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
