Estimated Horse Power?
Old Nov 11, 2012 | 07:09 AM
maxjivi05's Avatar
010 Block 350 With Street Dominator Intake, Camel Double Hump Heads, Stock Cam etc... Holly 600
Any estimates?
Not sure the casting # on the camel double hump heads but when I looked it up on a stock 305 it will push 300 Horses.
Anyway any totals? Thanks - just curious my car is almost done just waiting for the fuel pressure regulator sealant to cure
Old Nov 11, 2012 | 10:40 AM
Re: Estimated Horse Power?
Stock Cam
Which one? Details matter.
010 Block
Doesn't really matter.
What DOES matter however, is the pistons. What ones of those did you use?
What prep has been done ot the heads? Are they the ones w bolt holes, or no?
Sounds like .... you'll be revisiting that... Teflon tape VERY CAREFULLY APPLIED (so that fragments can't tear off and get into the fuel stream) is the way to go
Old Nov 12, 2012 | 06:51 AM
maxjivi05's Avatar
Stock Pistons - Flat Top ...
No Holes on the Heads just stock Camel Double Hump Heads but Will need to go get a new set of Vortec Heads apparently the Camel ones are a little warped had a small leak dribble down of coolant
Old Nov 12, 2012 | 12:07 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
On the intake side or the block side of the head? Either way, I'd get it fixed before running the motor. If its the intake side, its probably dripping coolant into the lifter valey which means the coolant is mixing with oil. If the block side is warped, well I shouldnt really have to say why thats bad.
Old Nov 15, 2012 | 11:55 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
You won't regret the vortsc heads. Waaay better than the ones you have now.
Old Nov 16, 2012 | 08:33 AM
1gary's Avatar
HP Estimate?? A bazillion hp and ten million ft pounds of torque.There without a single thing to go on,are ya happy?? I sure hope so,I did the best I could given what you gave me to work with. Certainty there are computer programs you can buy a paper dyno.Answer it's questions and it will give you some idea.But by answering those questions your going to learn a thing or two.......................
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
bellez77
Sep 5, 2015 08:39 PM
scottmoyer
Sep 5, 2015 09:33 AM
sailtexas186548
Aug 24, 2015 10:11 PM
