It's running again. Big block with swap headers and 3 inch dynomax race bullets
Old Jan 10, 2013 | 04:56 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
http://www.facebook.com/#!/photo.php...type=2&theater
Old Jan 11, 2013 | 11:21 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Re: It's running again. Big block with swap headers and 3 inch dynomax race bullets
There's nothing here, unless I have to sign in to FB....and i dont do FB.
Old Jan 11, 2013 | 11:34 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Not a lot of oil getting to the rockers?
Soild cam?
Do you really have a t-5 behind it still?
Nice color! My orange camaro had a big block for awhile.
Old Jan 11, 2013 | 08:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Originally Posted by 92 BBC Z
.and i dont do FB.
I don't do FB either but a video does come up on that page and I can play it.
Old Jan 12, 2013 | 11:40 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
hydralic cam 550 lift 290 something duration. I checked the oil pressure since this video i even drove the car the other night. it has 70 psi oil pressure. in the video the motor had run for maybe 20 seconds from being put back in. i have to say the race bullets are louder than i thought they would be.
this time around with the car i changed out the oil pan, put a shift kit in the th350, relocated the oil sending unit. added the swap headers, built the 3 inch exhaust, added a trans cooler. all of this started off as a easy header swap but the headers wouldn't work with my oil pan and one thing led to another.
Attached Thumbnails It's running again. Big block with swap headers and 3 inch dynomax race bullets-20130106_204024-2.jpg   It's running again. Big block with swap headers and 3 inch dynomax race bullets-20130106_204030-2.jpg   It's running again. Big block with swap headers and 3 inch dynomax race bullets-20130106_204621-2.jpg
Old Jan 13, 2013 | 12:51 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Years ago when I was using the Hooker Header swap headers, I was using 3" bullet mufflers. I never liked them. My Ed Quay headers use a 4" slip on collector. I installed some 4" Magnaflow race mufflers (the larger oval ones). They have zero restrictions for the flow. No baffles, no louvers etc inside to stop the flow. They're quiet enough that I can hear the engine, tire squeal etc while going down the track. I've had a lot of people tell me that the car sounds great going down the track.
The only disadvantage is the 45 pounds of exhaust system after the collectors.
Old Jan 13, 2013 | 11:38 AM
92 BBC Z's Avatar
Negative, still nothing, no video.
Old Jan 13, 2013 | 03:27 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
try this instead
Old Jan 13, 2013 | 03:34 PM
Twin_Turbo's Avatar
set as private!!!!
Old Jan 13, 2013 | 03:36 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
just set it to public geez I don't share vidoe much so i'm learning. Facebook was easy just publish from the phone and set to public youtube its try to upload fight with it and finally they upload then have to set to public
Old Jan 13, 2013 | 03:38 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Same here.
Other vid says " Private Video " & doesn't play.
Maybe it's an ISP thing?
( edit )
j, it's ok-- I can't get photobucket to share my pics!! O_0
Old Jan 13, 2013 | 03:51 PM
92 BBC Z's Avatar
Ah yes. I needed a good "fix", thanks for sharing.
Old Jan 13, 2013 | 03:55 PM
Twin_Turbo's Avatar
Rev it!! please nice choppy idle but we want to hear it roar
Old Jan 13, 2013 | 04:37 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
when i get someone to hold the phone my daughter says it's too loud so she won't
Old Jan 13, 2013 | 05:22 PM
Car: '87 Camaro
...DOH...
Figured it out!!
Click the
YouTube
not the Play arrow!!
Sounds healthy!!
Old Jan 13, 2013 | 09:19 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Sounds very good man!
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
InfinityShade
Aug 22, 2015 08:00 PM
midias
Aug 22, 2015 01:42 AM
