HELP! How to tell LB9 from L98
Old Jan 13, 2013 | 05:32 PM
Mayt13's Avatar
Car: 1989 Chevy Camaro IROC Z28
Axle/Gears: Stock
Ok, I promise I googled this before asking but how on earth are you supposed to tell a L98 from a LB9? All the exterior components are absolutly identical. I tryed to google the casting numbers but I came up with about 11 different results! Some sites say its 14011148 other sites say it's either 14088548 or 14101148.
What I'm looking at is supposedly a 88 roller cam L98. I need to know the casting numbers for the heads and the block because its outside the car!
Old Jan 13, 2013 | 07:01 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Re: HELP! How to tell LB9 from L98
They are stamped 5.0 or 5.7 on the back of the motor above the bellhousing, drivers side.
'86 and newer will have an alum housing on the rear of the crank for the one piece rear main seal. '86's are oddballs with hyd flat tappet cam's and id'd by the fact that all the intake bolts will be at the same angle.
'87 and newer were roller cam'd and the middle 2 intake bolts were revised and point straight up to make them easier to get to. And will also have center bolt valve covers.
Old Jan 13, 2013 | 07:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Early 2 pce RMS engine will have the casting number where shown in the pic below
Late 1 pce RMS (roller cam ) engine will have 5.0 or 5.7 there and the casting number in same position on opposite side
Pic also shows the alum housing on the crank for 1pce RMS engines mentioned above
Let us know what the casting # is
Old Jan 14, 2013 | 02:59 AM
Mayt13's Avatar
Axle/Gears: Stock
I didn't see any casting # there (on the back behind the left or right cylinder head) but I was able to find the casting number for the head which was 14101083, which at least means it has at least one 350 head on it.
He had obviously just pulled it out of his camaro, which had the correct vin. The eighth digit was a 8 instead of an F.
Idk, I'm just really hesitant. LB9s are worthless.
I'll double check for the vin when I go to pick it up tomarrow
Old Jan 14, 2013 | 04:05 AM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
LB9s aren't so worthless when they are hooked up to a 5 speed or when they can just be switched to a 350 block but use the existing TPI plenum.
remember if the 8th Digit is 8 then it's a 5.7 if its an F then its 5.0 and 14101083 is a casting number for '87 and up 350 64cc heads
Old Jan 14, 2013 | 09:08 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Its hard to look for behind the driver head. It can be dirty back there. Need degreaser/brake clean to really see the numbers but it should be there. Atleast you have a 350 head so it should be an L98
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
