Question about starter
Old Jan 17, 2013 | 11:37 AM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Hi everyone its been a while since i have posted. About a year and a half ago I had a 383 stroker installed into my 91 rs as well as eliminated the ecm and switched to a carb set up, I kept the old starter on it and now its finally decided to crap out on me my question is should I replace with a another stock starter or is their another option that would help the performance of my car. Also I know in therory how to replace the starter but I have never actually done it does anyone know of any good write ups that would be helpful.
Old Jan 17, 2013 | 03:35 PM
5spd-iroc's Avatar
Car: '85 iroc-'13 powerstroke H&S tuned
Engine: 406 sbc full roller
Transmission: t5 soon to be t56
Axle/Gears: stock
Re: Question about starter
i have a off brand mini starter from summit, cant remember the brand but not much more than a standard starter, and spins my 406 over way better, its pretty easy to change, unhook positive cable from battery, unhook positive cable from starter and remove wires off of the solenoid, pull the 2 bolts and the starter should come right out
Old Jan 17, 2013 | 05:07 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Also keep track of the shims and the placement. It's always a good idea to check gap, but replacing the shims in the exact same order should be good starting point.
Normally your picks on starter types is limited by space requirements, such as long tube headers.
Old Jan 17, 2013 | 07:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The factory Denso style mini starter from a 88-96 Vette is a popular replacement
Reman ones always on that auction site
http://www.ebay.com/itm/Corvette-Sta...84de70&vxp=mtr
https://www.thirdgen.org/forums/post...121-post3.html
https://www.thirdgen.org/forums/tech...atability.html
https://www.thirdgen.org/forums/tech...k-starter.html
https://www.thirdgen.org/forums/elec...1-starter.html
Old Jan 19, 2013 | 10:12 PM
Engine: 383 stroker
Thanks for the help
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
milk
Aug 10, 2015 06:26 PM
