305 TBI to 403 olds
Old Feb 7, 2013 | 09:38 AM
  #51
Donnie(91rs)G's Avatar
Car: 1991 camaro rs
Engine: 305 TBI
Transmission: 700-r4
Axle/Gears: non-posi
Re: 305 TBI to 403 olds
Ok guys question again so my 91 has the smog controll with the lines coming out of my manifolds and it has 2 little plugs/sensors on the box under the cover, I unhooked those last night and my car ran no differently and did not throw a code, am I ok to run headers and delete that smog box? Egr will be left alone, I was told by unhooking those my car would rough idle but its running just fine without them hooked up. Should I be fine to take off those manifolds and delete that smog box and run headers?
Old Feb 7, 2013 | 10:31 AM
  #52
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
It will run fine if you remove the lines and the Air Pump.
It will not be legal as far a federal emissions are concerned though.
Old Feb 7, 2013 | 10:39 AM
  #53
Car: 1991 camaro rs
Engine: 305 TBI
hey guys so my 91 rs has the smog control with the black box that has 2 sensors on it and all those lines running out of the manifolds over to that black box or charcoal if thats what its called, i am wanting to run headers, but i heard that by deleting that box and those plugs or sensors if you will, it will make my car rough idle and cut out, well i unplugged them last night and it ran just fine, no change at all, so am i ok to take those manifolds off and take that smog box off and run headers?
Old Feb 7, 2013 | 10:40 AM
  #54
Car: 1991 camaro rs
Engine: 305 TBI
are those the only 2 sensors for the computer for all that emissions bs?
Old Feb 7, 2013 | 10:46 AM
  #55
Car: 1991 camaro rs
Engine: 305 TBI
and also will any shorty headers for a small block work? or is there a certain type of headers these camaros need?
Old Feb 7, 2013 | 10:47 AM
  #56
Car: 1971 Camaro
Engine: 427
Yes you have to have headers for an 82-92 F body. Other headers will NOT fit.
Old Feb 7, 2013 | 11:03 AM
  #57
Car: 1991 camaro rs
Engine: 305 TBI
where are the o2 sensors on these f bodies?
Old Feb 7, 2013 | 12:51 PM
  #58
Car: 1971 Camaro
Engine: 427
There is only one, in the driverside manifold.
Old Feb 7, 2013 | 02:03 PM
  #59
Car: 1991 camaro rs
Engine: 305 TBI
as ive been looking for headers. none of the headers are specific for camaro, they say will fit 1991 rs 305 camaro but are also compatible for like trucks and other cars and look no different than the headers i planned to buy from my friend
Old Feb 7, 2013 | 02:17 PM
  #60
Car: 1971 Camaro
Engine: 427
Then you are looking a t the wrong headers, or its a stock image. "item nay differ from Pic"
Go to the exhaust forum and read up.
Truck headers will not fit our cars.
Old Mar 11, 2013 | 12:31 PM
  #61
Stunt_Man's Avatar
Car: 2x T/A
i have problem again
starter from 95' camaro (5.7 t56 ) will fit to my 350 and th700 (153t flex plate) ?
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
