88 Base with a 2.8L. Dropping a 350 in it.
Old Jan 29, 2013 | 11:39 AM
Revy's Avatar
Im looking into putting a 350 into my 88 Camaro. Ive heard that they crack the t-roofs. Anyone else have any light on that?
Also, I wanted to know the level of difficulty on the electrical portion of the swap. Harness swap? ECU swap? Any tips?
Old Jan 29, 2013 | 01:10 PM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Re: 88 Base with a 2.8L. Dropping a 350 in it.
well I really don't know. but I belive that all Third Gens are built equal in terms of structure so the car you have shoul be the same than my GTA that has the 350 in it.
That bean said all Third gens have a body that flex a lot and need to be reinforce with subframe connectors to handle better. I have never seen TTops craked just by the force of the engine and if they have that have to be a Hily modify engine.
So go aged and do the swap. so for the computer I dont know much about swaps but I belive you will need a complette Harness with the computer and if the instrument pannels don't work you will need to replace them as well.
David...
Old Jan 29, 2013 | 03:30 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
All F-bodies flex and I have seen hard tops get a crack in the roof right behind the side windows. Really a good set of sub frame conectors will do the trick for flex.
Old Jan 30, 2013 | 12:12 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Since you new to the boards ill give you this one but around here we like to stick to the method.
Check this thread out for a detailed explanation on swapping a v6 to a v8
https://www.thirdgen.org/forums/engi...swap-read.html
and as for the flexing just like the other members said SFC's will take care of it..
Welcome to the boards and have fun.
Old Feb 4, 2013 | 12:45 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Don't worry about cracking around the t tops! I've ran my car for yrs without a cage or connectors with a 1.60-1.49 60 ft.
Have a cage and connectors now though.
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
NWAsonoma
Aug 18, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
