mid 11 sec streetable 350 18-22mpg?
Old Feb 12, 2013 | 12:02 PM
  #51
TKR 88 GTA's Avatar
Car: 1988 GTA Trans Am
Engine: HSR 350
Re: mid 11 sec streetable 350 18-22mpg?
Easily too. My buddy up here has a 408 lq9 behind a 6 speed tho and he's able to get 24+ mpg and runs mid to high 12s in 5800ft elevation
Old Feb 12, 2013 | 03:18 PM
  #52
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by MMroc86
Alright, went & checked out the LQ9 tonight...
Going to pick this bad boy up tomorrow. minus the truck intake.
Getting 4l60e+engine+pcm for $1700 Its from an 05 silverado ss. I'm bulletproof unless the block is cracked right?
? can I use the truck pcm or will that be useless?
Time to abandon this thread and start a new one in the LTx and LSx subforum.
Old Feb 12, 2013 | 10:22 PM
  #53
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
My build thead
https://www.thirdgen.org/forums/ltx-...ml#post5488449
Old Feb 13, 2013 | 06:40 PM
  #54
nossbc's Avatar
Car: 1990 gta
Engine: 383,tfs heads,hsr
Axle/Gears: 12 bolt 3.73
Originally Posted by five7kid
4L60E is the same length as a TH700. However, the LS-series moved the mount location.
Output yokes are the same. 3rd and 4th gen driveshafts interchange (except for the early 4-speed manual and TH200C)
i was under the impression that the trucks with the 4l60e had a longer tail on the trans???
Stryker412
Sep 7, 2015 09:11 AM
IROCZ1989
Sep 4, 2015 11:54 AM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
willyjoejr
Sep 3, 2015 09:26 AM
