Old engine, no ECM
Old Feb 10, 2013 | 09:11 AM
skido's Avatar
Old engine, no ECM
I'm considering the possibility of replacing my 2.8 with an ancient 350 c.i.d. w/4bbl. Mechanical fuel pump. No sensors or ECM. Completely decomputerized. Is it possible?
I'd also like to hook it up to a turbo 350 or 400 auto tranny.
I can manufacture anything in the way of motor mounts and tranny xmembers.
Old Feb 10, 2013 | 09:34 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Old engine, no ECM
As for the ecm. Of course its possible. It actually would be easy IMO. Just have to do alot of dis wireing.
Old Feb 10, 2013 | 11:23 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
I'm doing basically the same thing but from TPI 305 700 to 355 turbo 350, I found all the info I needed from removal of the in-tank pump to cross member and torque bar mounting and electronic speedo hook-up and more.
All by using the search feature !
Good luck with your build.....
Old Feb 10, 2013 | 11:39 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
peruse the engine swap forum, seek & ye shall find
Old Feb 11, 2013 | 04:37 AM
skido's Avatar
Thanks, the search is on!
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
