305 to 350 issues
Old Feb 19, 2013 | 05:10 PM
miguelao33's Avatar
305 to 350 issues
Hi guys hope you help me... i have a 92 305 tbi and i want to swap it to 350..
as you know, the 1st gen of 350 divides in two types, the first one till 86 with 2 piece main seal and the second one with 1 piece main seal since 87..
I want to buy an aftermarket top end kit but the best ones and more complete ones are made for the 67-86 350´s and i want to use a block from 87 and up..
my question is.... can i buy this new block and put heads, intake manifold, camshaft, pushrods, valve covers, rockers, i mean:
87-00 block with 67-86 (everything else not counting obviulsy the crankshaft)??????
and then, to use a 4160 holley carb with my 700r4 trans, i just need two different brackets for the acelerator an TV cables??
thanks for your help. im exited about start swaping but i dont want to buy things i wont be able to use!
Old Feb 19, 2013 | 07:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 305 to 350 issues
Yes.
Welcome to thirdgen.org.
Old Feb 20, 2013 | 11:57 AM
miguelao33's Avatar
Oh thanks. And thanks god for your website it was very helpfull in all thing ive done to my car...
And what about the external accesories? can I use my 305 alternator, water pump, chest, steering pump, compressor and all pulleys? And what about the armonic balancer? this one wont work does it?
Old Feb 20, 2013 | 12:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It will all work.
Old Feb 20, 2013 | 12:11 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
all your accespories should swap over if your heads have the same bolt holes which most if not all do.
Old Feb 20, 2013 | 02:48 PM
miguelao33's Avatar
yes i tough the same.. Im thinking on the 60999 Edelbrock heads, do you think it has the holes for the alternator and compressor mountings?
Old Feb 20, 2013 | 02:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes
Old Feb 20, 2013 | 03:00 PM
miguelao33's Avatar
well the guys from summitracing chat told me all heads has the same accesory bolt holes from 69-95... so, i think will work, but i wanted your opinion anyway!
Old Feb 20, 2013 | 09:08 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
69-00 in some cases
Old Feb 21, 2013 | 12:58 PM
Devolont's Avatar
Car: 91 Camaro RS
Engine: LH6 5.3
Axle/Gears: 3.43 LSD
Is your car TBI, TPI or carb?
Old Feb 21, 2013 | 01:14 PM
Devolont's Avatar
Car: 91 Camaro RS
Engine: LH6 5.3
Wow, forgive my blindness. haha, do you plan on keeping the TBI then?
theshackle
Sep 17, 2020 08:26 AM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
st.evel07
Aug 13, 2015 06:15 PM
