305 to 355 transition
Old Feb 21, 2013 | 04:59 PM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
I am going to be purchasing a new Engine from summit racing. Has anyone switched to the 355 in their 3rd gen? Will the TPI system bolt on as well? I am wanting to know if it will bolt right into my 91 Z28 as a clean swap (as opposed to the LS1 engines). I am just purchasing the short block, and I will put the add on's as time and money allows. I just want to make sure I am getting a block that will fit in once complete.
Old Feb 21, 2013 | 05:51 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 to 355 transition
Short block assemblies don't include heads. Post up a link to what you're considering buying.
Old Feb 21, 2013 | 06:58 PM
Ikes 91Z's Avatar
Here is the link to what I am thinking. I am still in the beginning phases, and am wanting to make sure I am going to do it right...
http://www.summitracing.com/parts/ed...s/?prefilter=0
Old Feb 21, 2013 | 07:08 PM
Chad85T/A's Avatar
Car: 85 T/A
If those are the heads you are wanting to buy your lower intake won't directly bolt up. The 2 intake bolts in the middle of each head are angled differently than your current heads on your 91 plus your valve covers won't works either. These are the old style heads that have the perimeter bolt valve covers. 85-86 TPI base will bolt to them, but idk if you'll have to change anything else going to the older base. Maybe somebody else will know exactly.
Old Feb 23, 2013 | 08:28 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
A 355 is nothing more than a 350 thats bored .030" over.
Old Feb 24, 2013 | 04:55 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Slot the 4 center holes like the aftermarket intakes that fit both style heads
Old Feb 24, 2013 | 10:01 AM
Chad85T/A's Avatar
Car: 85 T/A
I was scared to advise him to start slotting holes lol. I have seen intakes screwed up from people not doing it right. I've got an old intake here at home that somebody attempted that and it didn't go well.
Old Feb 27, 2013 | 06:06 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Corvette base from any year tpi will bolt up or get a HSR (Holley Stealth Ram) or any aftermarket EFI intake.
Old Feb 27, 2013 | 06:42 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Here is a pic of what was done on mine when I got it. The original 85 manifold on a new 87 L98 engine. Click on the link below
https://www.thirdgen.org/forums/albu...ictureid=15453
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
