1991 camaro engine swap
Old 03-14-2013, 12:55 PM
Francis44's Avatar
Car: 91 Z28
Transmission: 700r
i just purchased a nice 91 z28 i was thinking of removing the engine and replacing it with a small block 400 carbureted that we had built for our 80 camaro that i no longer have does anyone know of problems i might have doing this swap will the trans still work also its the 700r
Old 03-14-2013, 01:32 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: 1991 camaro engine swap
Unless your 400 makes over 500 hp, you're much better off sticking with TPI.
Old 03-14-2013, 01:38 PM
Francis44's Avatar
Car: 91 Z28
Transmission: 700r
The 400is about 480 hp the motor in it now is stock
Old 03-14-2013, 01:42 PM
Car: 1971 Camaro
Engine: 427
What are your plans for the Camaro? Usage?
What are the specs of the 400?
Old 03-14-2013, 01:52 PM
Francis44's Avatar
Car: 91 Z28
Transmission: 700r
Mostly a weekend driver every now and then down the track just curious if the 400 would b easy to install since I would have to eliminate the computer and everything thx for ur input
Old 03-14-2013, 02:04 PM
Car: 1971 Camaro
Engine: 427
Well, depending on the specs of your 400 you may or may not have to eliminate the computer.
With the right cam, you can keep the tpi and will have a great drivable car.
Perhaps consider a cam swap and a stealth ram intake for a great set up.
Or course you could yank out all the EFI stuff for a carb, but that is just going backwards in technology
Old 03-14-2013, 06:21 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Let's see, "problems" putting a 480 horse carbureted 400 in a car that originally had TPI:
- Not emissions legal
- Will need to regulate fuel pressure down to a carb-friendly 4-7 psi
- Stock TPI pump probably not up to the task of supporting 480 HP
- Will need to figure out some way to turn on the fuel pump if you remove the ECM
- Exhaust inadequate to handle 480 HP - can we assume headers?
- 400 uses an externally balanced 2-piece rear main seal 168-tooth flexplate. Many 168-tooth starters interfere with 3rd gen headers. Mini starter typically solves this problem.
- TH700R-4 not up to the task of handling 480 HP stock. Some upgrades, or a complete rebuild, to be expected.
- Stock stall probably not friendly to a 480 HP 400 SBC.
- Without the input from the EFI system to the ECM, and/or without the ECM, the torque converter clutch won't lock up when cruising. Can be fixed with a simple switch, or one of several kits available.
- Typical carb throttle arm not compatible with the TH700 TV cable. A geometry corrector bracket available for most popular carbs (Holley, Edelbrock).
That's for starters. The rest depends upon the details of the 400.
Old 03-16-2013, 09:27 PM
D&S 85 IROC's Avatar
Car: 85 IROCZ
Engine: 350 TPI with a fast EZ efi
Transmission: t-5 conversion
Axle/Gears: 3;42
WOW ya shot a big hole in that
Old 03-18-2013, 09:19 AM
Francis44's Avatar
Car: 91 Z28
Transmission: 700r
Thx for ur input were pulling the trans today was going to send it out for the rebuild I was told tht a th400 trans would b better to install in the car what's ur opinion on using tht instead if the 700r
Old 03-18-2013, 09:26 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Your gonna need steam holes drilled into the heads for a 400. Unless you use the 400 heads and in that case you would have to go carb.
Old 03-18-2013, 09:30 AM
Car: 1971 Camaro
Engine: 427
Trans, really depends in engine and use.
For a street driven car, th700r4 is way to go.
Th400 will require a cystom crossmember, custom torque arm mount, drivesshaft, different shifter, and you'll be losing overdrive.
Old 03-18-2013, 10:17 AM
Francis44's Avatar
Car: 91 Z28
Transmission: 700r
Sounds like the 700r is gonna b the easiest install the converter lockup kit should b good
Old 03-18-2013, 10:43 AM
Car: 1971 Camaro
Engine: 427
So, no hopes of keeping the efi?
Old 06-16-2014, 02:35 PM
Danny350's Avatar
Can the 700r4 hold up to 480 hp if not what do I need to do too it or what is a good 4 speed trans to buy I need to know Bc I'm putting a ls3 in my 91 camaro plz help
Frozer!!!
01-19-2024 04:55 PM
theshackle
03-05-2017 06:37 PM
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
Quick Reply: 1991 camaro engine swap
