TPI short block swap
Old Apr 25, 2013 | 03:53 AM
Birdman1987's Avatar
Hi all,
I have to install a short block into a TPI. It has all the wiring harness, heads, sensors, etc.. But it has a missing short block.
My question is: can I use an old carbed short block or any other to change the bottom end? Or can I use only the TPI short block to work it properly?
Thank you!
Robi.
Old Apr 25, 2013 | 05:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is nothing unique about TPI that would require use of a special block. Any small block Chevy from '57-up will work (later ones are better, though).
anesthes
Mar 10, 2016 10:35 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
BBSDesigns
Aug 11, 2015 07:39 PM
