Starter wire issue
Old Apr 28, 2013 | 09:46 PM
Richgta's Avatar
Starter wire issue
Here the deal im doing a 350 swap it originally had a 305 tpi but swapped it for a goodwrench 350 and the wiring for starter doenst match anyone have this problem what do I do
Old Apr 28, 2013 | 11:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What starter did you use? What wires aren't matching?
Old Apr 28, 2013 | 11:36 PM
Richgta's Avatar
Re: Starter wire issue
stock starter and I have no clue thats just wat my mechanic said some wires wearnt right
Old Apr 29, 2013 | 01:33 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Neither do we until you come up with a bit more info
stock starter
For what ; the 305 or the new engine ?
If you have the original 305 starter in there there should be no differences
Old Apr 29, 2013 | 05:31 AM
Engine size really doesn't matter, or which starter it is either. It is not rocket science.
Wires with BIG terminals go on the BIG terminal.
Wires with LITTLE terminals go on the .... I'll let you figure out which terminal.
Old Apr 29, 2013 | 02:08 PM
five7kid's Avatar
What you seem to need is a competent mechanic.
Caspar
Jun 19, 2016 11:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86Base
Aug 8, 2015 01:34 PM
