Another engine swap
Car: 1992 RS
Engine: 5.7L
Another engine swap
I have a 92 RS. i have canned the 5.0 for a 5.7, getting rid of the TBI. Also, i ditched the 700R4 for a T5. I want to get rid of the ECM and wiring since i'm not useing the TBI anymore, but the speedometer isn't cable driven. so ther is another problem there on how to make the speedometer work.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Another engine swap
So it is a gearbox question ; not a engine swap question?
Should be here in trans dept
https://www.thirdgen.org/forums/tran...ns-drivetrain/
Do a
under T5 VSS
lottsa info
https://www.thirdgen.org/forums/tran...-swap-vss.html
Do a
under T5 VSSlottsa info
theshackle
Mar 5, 2017 06:37 PM
