Best Ca Smog Legal camshaft small base
Old May 21, 2013 | 02:31 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Transmission: 700hp 700r4
Axle/Gears: 3:45
Looking into the Lunati 224/232 .544 122 is this small base?
Lpe has 211/219 .530 .560 Heard these are small base with Lingenfelter heard they were also good cams.
Lpe 219/219 .560
Im needing a small base camshaft for 383ci hyd roller clearance standard 400 crank an 6" rods.
Heard you can go large as 226/232 .580 lift smog legal. Is that a custom grind?
I currently have a zz4 208/221 .510 and Im really running like there is no cam as I heard people explain it that way.
I dont want to have to do this, I heard with the small base cam you dont have to clearance. I have a Vortec hyd. 4 bolt main block.
The .580 sounds nice but I want to be under the limits.
db057
Apr 28, 2019 07:45 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Jorlain
Oct 8, 2015 01:57 AM
64goatman
Sep 9, 2015 01:09 PM
Formula_88AE
Sep 3, 2015 01:47 PM
