305 knock sensor - TPI Swap
Old Jun 20, 2013 | 01:14 PM
25th92RS's Avatar
Car: 1992 RS, 2000 Z28
Engine: LO3 with TPI Swap, LS1
Transmission: 700-R4, 4L60E
Axle/Gears: 3.42 with TruTrac LSD
I'm on the tail end of completing my TBI to TPI swap. I'm currently getting SES Code 43 (knock sensor).
I ended up using the original TBI knock sensor since I had looked up if the sensors were different and the info I found at the time had said that they were not. Now that I'm getting an SES code I looked it up again and the part numbers are different for a 305 TBI sensor and a 305 TPI sensor (which is what I should have done to begin with!).
Does anyone know if these knock sensors are interchange able between the TBI and TPI? I'd rather know that it is, in fact, different before I pull the knock sensor out and flood my nicely redone engine bay with coolant.
Thanks in advance for the info!
Old Jun 20, 2013 | 01:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 knock sensor - TPI Swap
One thread asking this question is more than enough !
Old Jun 20, 2013 | 03:27 PM
25th92RS's Avatar
nothing is never enough when you're hot pressed to finish a project
Old Jun 22, 2013 | 03:27 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
anyone know if these knock sensors are interchange able between the TBI and TPI? !
No
And you also realize a code means a problem somewhere in the whole circuit ;
not just that the major item of that circuit, say in the case of a DTC 43 the KS, itself is actually faulty
db057
Aug 22, 2015 08:17 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
gwade12
Aug 8, 2015 08:17 AM
