2.8 mpfi to blown 355 carbed
Old Jun 28, 2013 | 02:19 PM
86Base's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 383 Stroker
Transmission: stage 2 2004r
Axle/Gears: 3.55
hi im currently working on a swap to carburetor and i know most of the basics regarding the fuel system, chassis and turbo work but am still unsure of the wiring. do i just rip out the v6 engine harness? what happens to the gauges and cooling fan? and how to properly wire this beast of a motor?
Any help would be greatly appreciated.
Old Jun 28, 2013 | 07:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 2.8 mpfi to blown 355 carbed
Plenty of info in the Carb dept
https://www.thirdgen.org/forums/carb...um-please.html
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Reinstall all the old sensors into new engine to run the gauges.
Have to re-wire the fan and fuel pump to run without the computer . Do a search ; well documented on here
Need to convert the V6 tacho to V8 config
https://www.thirdgen.org/forums/elec...oeter-fix.html
Pink power wire to the new coil , purple starter wire to the new starter
Done
Old Jun 28, 2013 | 08:10 PM
86Base's Avatar
Engine: 383 Stroker
Axle/Gears: 3.55
Thanks for the reply, you cleared up some of my questions. Heres another one ive read almost every thread about this and even then the are not clear as of the wiring is the starter wire part of the engine harness or the fuse box? And should i wire the fuel pump to a switch or to key on?
Old Jun 28, 2013 | 08:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Should be in the engine bay harness that runs down to wherever you starter WAS
A smart person would hook up the old oil pressure switch from the V6 so it operates the fuel pump as soon as the engine is cranked over
( engine will fire on whatever fuel is in the carb bowls )
Using the OP switch means the fuel pump always turns off when the engine is turned off ; no need to remember to switch off before leaving the car
Then have a switch to the fuel pump relay so the pump can be run to prime the carb if the engine has been sitting a while and the fuel has evaporated.
Switch also serves as a manual backup should the OP switch fail
Just duplicate the factory setup ( wiring is already in place )
Old Jun 28, 2013 | 09:05 PM
86Base's Avatar
Engine: 383 Stroker
Axle/Gears: 3.55
so what your saying is to tap into the oil pressure with to also run the fuel pump and run a switch before the fuel pump relay for a backup safety switch. its not an old motor, i built it from the ground up. should be getting the turbo next week or so. cant wait!!!!
Old Jun 28, 2013 | 09:54 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
run a switch for a backup safety switch.
As I already described , the OP switch is the SAFETY switch.
It will only run the pump when the engine has oil pressure and will shut the pump down automatically when the oil pressure drops ( engine off )
Your old motor should have had a OP switch for the pump , reuse that
No
Have a switch CONTROLLING the relay so you can run the pump manually.
LOOK at the circuit diagram I posted FOR YOU
From the factory ,the relay and the switch are wired in parallel ; if one dies the other will still operate the pump.
But because you don't have EFI , you don't need the fuel rail prime function anymore so you use the OP switch ONLY for normal use
Old Jun 28, 2013 | 10:03 PM
86Base's Avatar
Engine: 383 Stroker
Axle/Gears: 3.55
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
codeysabatini
Nov 10, 2015 04:07 PM
BLK87Z
Sep 18, 2015 11:29 PM
Springster
Sep 13, 2015 01:38 PM
rjcme
Sep 5, 2015 01:23 PM
