I'm going crazy here (Motor mounts)
Old Jun 29, 2013 | 06:32 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I'm dropping my SBC in today. I am 100% positive my motor mount brackets are on the right sides. The motor mounts are just rubber like stock. I dropped the engine in. The driver side motor mount lines up perfect. The passenger side does not. It needs to be shifted towards the driver side. And the back needs to drop down. Nothing I do will make it line up. Anyone have any suggestions?
Old Jun 30, 2013 | 06:40 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Re: I'm going crazy here (Motor mounts)
Update if this comes up in a search for anyone. Make sure nothing is hitting in the back. Wiggle the engine as it's going on the mounts. That worked for me. Also, drop your engine and tranny in together. I wish I would have.
Old Jun 30, 2013 | 09:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Mounting the engine on the K-member outside of the car, then dropping the car over the engine/trans/K-member, is also a lot easier.
Old Jul 4, 2013 | 11:50 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Can you do that with a regular jack and jack stands?
Old Jul 4, 2013 | 01:04 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I had to leg press my engine into place to get it to seat right. Motor mounts are ALWAYS a PITA.
Old Jul 5, 2013 | 01:59 AM
five7kid's Avatar
If you're referring to my post, you need to lift the front end of the car. Can't be done with a Jack.
Old Jul 5, 2013 | 10:12 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I'm not sure that would have been easier for me. It wasn't horrible putting the tranny in after. But much harder to line up than I thought. Even on a tranny jack.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
