305 tpi to 96 vortec with HSR
Old Aug 20, 2013 | 03:41 PM
Dskeezy16's Avatar
Car: 1985 Firebird Trans Am
Engine: ls1
Transmission: t56
Axle/Gears: 8.8 Ford 3:73's
Hi I have 85 trans am with a 305 tpi currently in it. My plans are to swap in a a 96 vortec 350 put an HSR on it, cc503 cam, and to use an ebl flash with the stock tpi harness. My dad just told that there was a crankshaft and camshaft sensor in this motor. Can I still make it work with the tpi harness and ebl flash? Will I experience any other problems?
Old Aug 20, 2013 | 04:22 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 tpi to 96 vortec with HSR
You will need to use a computer controlled divorced coil distributor from a 87-92 tpi/tbi.
Your dad is correct but you will not use the crank sensor leave the sensor in the timing cover or remover the reluctor and slap on another timing cover. The cam sensor will be replace bye your dizzy. you will need to upgrade the injector to 22#hr contact vendor southbay great prices and service.
Old Aug 20, 2013 | 06:59 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
Thank you very much for the response.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
