Budget 406 What will it make?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
406 True Street Driven built on great deals and hand me down parts:
Production 400 block
Production 400 cast Crank
SRP Professional Series Flat Top pistons w/rings 405 grams (1.5/1.5/3.0 mm rings)
Pro Comp pro-lite Rods 6.00in
RHS Pro Topline 235 heads w64 chambers (out of the box)
Edelbrock Victor E (out of the box)
Holley 950 HP carb
Canton 1in. Super Sucker
Bullet S/R .930 bc .626-.626 lift 255*-263* dur @ .050 114* lobe sep
installed at 108*
Harland Sharp 1.6 rockers
Professional Prod 7qt pan w/melling M55a pump
MSD pro billet Dist
MSD digital 6 box
Headman Hustler 65165 step headers 1-5/8 to 1-3/4 w/3in collectors
Headers and cam purchased from members here,
fun and streetable without going above 7000 rpms, so what are your thoughts guys?
Holley 950 HP carb
installed at 108*
MSD pro billet Dist
MSD digital 6 box
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
1 Post
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: Budget 406 What will it make?
I'd personally stroke a 350 before building a 400, but that's just me.
Received 1,714 Likes
It should make 500 HP eeeeezy, maybe 550 if your tuning skillz are truly mad.
ONCE.
I don't think it'll make it twice.
The crank will break at the front; either the snout will break off, or it'll break right in front of the #1 throw, or it'll break where the #1 throw meets the rod pin.
Guess how I know this...
1 Post
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
I appreciate all the advise, and know the horror stories of the 400 blocks, but I've seen them take a ton of punishment with less parts than I have in mine and get hammered with nitrous on top of that for money during Street races, but this combo was put together inexpensively to be a much better than stock street cruiser, no more, no less, here is the parts breakdown:
Production 400 block ( FREE)
Production 400 cast Crank. ( FREE)
SRP Professional Series Flat Top pistons w/rings 405 grams (1.5/1.5/3.0 mm rings) ($605.00)
Pro Comp pro-lite Rods 6.00in. ( FREE)
RHS Pro Topline 235 heads w64 chambers (out of the box). ($300.00 fully assembled)
Edelbrock Victor E (out of the box).( $100.00 brand new in box)
Holley 950 HP carb. (Had from my Pontiac since going Dominator)
Canton 1in. Super Sucker. (Had from my Pontiac since going Dominator)
installed at 108*. ($275.00)
Harland Sharp 1.6 rockers. ($235.00)
Professional Prod 7qt pan w/melling M55a pump (complete kit just under $200.00)
MSD pro billet Dist ($300.00 purchased w/digital 6 in package deal)
MSD digital 6 box
Headman Hustler 65165 step headers 1-5/8 to 1-3/4 w/3in collectors ($300.00)
Magna fuel 300 pump ($250.00)
Fuel cell. (Free)
also assorted gaskets, ARP head studs, other fasteners that nickle and dime you along the way, but you get the idea, kinda inexpensive dont you think?
Plus glass hood, k-member, suspension parts, manual steering box, ac delete heater box, astro van steering shaft, and other goodies found on this and other sites I frequent, I figured it could make about 550 H.P. And not have trouble from new, Camaros, Stangs, and Vettes, as well as the AWD tuners!lol
MSD digital 6 box
Fuel cell. (Free)
1 Post
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Combo includes all Spohn suspension from Trans Cross member, Torque arm, driveshaft loop, rear trailing arms, and panhard bar, Turbo 400 w/shift improver and 10 in. converter, and 3.73s w/limited slip in the factory rear also the set of Weld Stars I purcased with the front tires for the sum of $300.00 from a local racer who upgraded the rims and tires on his T/A!
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
What will you be doing with the car? Daily driver? Weekend warrior? Drive-in cruiser?
1 Post
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
![burnout](https://www.thirdgen.org/forums/images/smilies/burnout.gif)
Engine: LS1/LQ4
To understand whether the build you're spec'ing out will be disappointing for the use it sees, won't last, etc.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I'm not going to talk about the durability, but that is a 550 to 575hp motor if it is tuned correctly.
1 Post
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
