406 sbc no hot start
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
hey guys
I got what i hope is a quick question, when my 406 gets up to operating temp,when i shut it off and go to restart it it wont do anything it tries to crank once if luicky then thats it,all ignition is solenoid cables etc, i was wondering if this sounded more of a battery or starter problem to you guys the battery is semi new 2 yrs old and 950ca should i go bigger battery? new starter?its kinda embarrasing lol, also timing is correct,,any ideas would be much appreciated!
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: 406 sbc no hot start
Mini starter
Heat shield // wrap
Ford style solinoid mounted away from heat
Some ideas anyway
Heat shield // wrap
Some ideas anyway
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
If i had to guess without being there i would say the starter is on it's way out. Could it be vapor locking though is also something to look into.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
a well documented problem ,heat soak of the starter solenoid ,
As t-top havoc notes ,a remote solenoid usually solves it
http://www.chevyhiperformance.com/te..._no_start_fix/
http://www.streetrodstuff.com/Articl...tart_Problems/
https://www.thirdgen.org/solenoid
yes its a stock 400 starter probably a dumb move on my half, so im gonna with majority says and bite the bullet and get a new mini starter,what kind do you guys recommend? do i go witha metal heat shield to? or starter blanket? thanks for all the help so far guys!!
Car: 82 Z28
Transmission: T400
you can turn it over by hand when its hot why you ask??
Transmission: 4L80E/4L80E
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
when my truck did this, it was the starter ... and i think he asked about turning it over by hand to see if things (like the rings) were getting to tight when it was up to temp
Car: 86 TRANSAM
Engine: 406
I have used a stock starter on my 406 for 9 years without a single problem. I started with a single wrap over the starter and solenoid/ When it got brittle, I put on a new one but just put it over the original. I also have SLP 1 3/4 inch headers on it. I did have a problem like yours on my 90 IROC. After 3 starters in 2 weeks, I found it was a wiring problem. The previous owner removed an alarm system and had a short wire. He spliced in a wire, but it was a lighter gage and would not carry the load when it got hot. Replaced it and no problems for the last 15 years.
Engine: 4++,350 & 305 CIs
I run a small flex plate and a stock 96ish corvette mini starter.
Haven't had 1 start issue in 10 years. I even have 1 (coated) hooker super comp header tube that lays on the starter.
It's cheap and easy to rebuild these if it ever needs it.
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 11, 2015 10:11 PM
