90 Camaro 5.7 in 91 Trans Am 5.0?
Old Dec 12, 2013 | 03:43 PM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
I have a 1991 Pontiac Trans Am with a bad 305 (Piston rings) so I think its time to go for a 350.
My question is I found a good 1990 350 from a Camaro and was curious if that would work since its a different model year and "sort of brand". Someone told me the pontiac motors were different form the chevys in the 90's....
I know there is a difference in the ESC Module between 80's and 90's thirdgens, so I'm told but is that a problem for a 91 350 to a 90 305? I guess there was a internally and externally mounted ESC module which was based on the year. Is that a problem for this swap?
Basically I just want to make sure I can do this without any major problems or anything special I have to do other than new chip?
Also my firebird is a manual, does that cause any issues if it came from an automatic?
Old Dec 12, 2013 | 06:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 90 Camaro 5.7 in 91 Trans Am 5.0?
Should only ask a question in one dept
https://www.thirdgen.org/forums/tpi/...maro-into.html
It gets confusing when multiple threads are running
Old Dec 12, 2013 | 06:51 PM
fiveoformula's Avatar
Car: 1988 Formula Firebird
Engine: 5.3 LM4
Transmission: 4L65E
Axle/Gears: 3.42 True-Trac
As far as bolting the engine in, it will a straight swap if both engines are TPI.
There are few parts that you will need that are specific to a 350 like the knock sensor. the 305 computer will probably run the 350 OK but it will need tuning to run perfect since Fueling will probably be a little off. So may want to read up on tuning and learn to do that or buy a custom burned chip since there is no factory 350TPI/5speed computer.
Old Dec 13, 2013 | 03:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're getting the responses you need on the other thread.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
Exxon Limited
Aug 9, 2015 08:13 PM
