3970010 block stamped V0907TJA
Old Jan 23, 2014 | 02:40 AM
88iroc86z's Avatar
Car: 86 Camaro Coupe
Engine: currently building a 355
Transmission: unsure what it will end up with
Axle/Gears: 10 Bolt 2.73
Hey guys I am working on a block and it is a 3970010 block however it is also stamped V0907TJA. Now I have tried using google to search what it means and can not figure it out. Does any of you guys know what this number means?
Old Jan 23, 2014 | 02:44 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 3970010 block stamped V0907TJA
the block number is the casting id, the other number/letters you listed are the suffix from the vehicle the engine was originally installed.
Old Jan 23, 2014 | 02:46 AM
Engine: Lb9
Transmission: M20
http://lmgtfy.com/?q=1969-79+3970010...casting+number
Old Jan 23, 2014 | 09:05 AM
88iroc86z's Avatar
So this is what I found at
http://www.nastyz28.com/gm-chevy-cod...s-suffix-7.php
V= Flint engine
0907= September 7th
TJA=1973 350, Conv. Cab, 160HP 4Bolt, C-20 to 3500 or
1979 350 FRWD. Cab, AT L LS9 (Vin), 165 HP 4 Bolt, C30 & 3500
Thanks for the help guys. I knew I could count on you.
Old Jan 23, 2014 | 05:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Only tells you have a 40 year old 350 block that was once in a truck
https://www.thirdgen.org/forums/post...12-post18.html
https://www.thirdgen.org/forums/post...44-post48.html
https://www.thirdgen.org/forums/post...90-post32.html
Old Jan 23, 2014 | 07:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The partial VIN number close to the V0907TJA can pinpoint which year it's from.
Old Jan 28, 2014 | 01:47 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Thats a Great block..... It was used for 3 diffrent Engine sizes. the 307,327,350. I have the same Engine... It was originally a 350.. But I went through rebuilt it with a large journal 327 Crank... With todays Engines though... Its really not what it used to be. I wont do anymore old SBC engines......... Its not worth it anymore with the technology and better running motors we have today...........
Old Jan 28, 2014 | 02:31 PM
88iroc86z's Avatar
There is no vin next to the V0907TJA stamp.....
Old Jan 28, 2014 | 03:30 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Just another lump of cast iron
Old Jan 28, 2014 | 05:41 PM
88iroc86z's Avatar
I know its just another engine... I was just looking for info on it so thanks to everyone that was helpful and all others plz go to another thread to bash
Old Jan 28, 2014 | 07:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Get the block decked for squareness and it's just another 010 casting 4" bore block. Decking the block will remove all those stamped in numbers.
Old Jan 28, 2014 | 09:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Exactly that.
What it was when it left the factory is little relevance 40 years later unless you can prove it has never been touched.
Old Jan 28, 2014 | 10:12 PM
88iroc86z's Avatar
Yeah I am saving money and getting the body ready for the machine shop to assemble and do everything to the engine
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
