Big Block swap results for handling
So I was wondering, what'd the results of swapping a big block into my '89 Camaro be on handling? Will they be disastrous? Is there any way to combat these potential negative side effects of swapping for a BBC?
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: Big Block swap results for handling
If you use a big block with aluminum heads, by the time you take out things like air conditioning to get it to fit, there really is not a lot of weight diference
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah if you do it right I think the weight difference is relatively small compared to a full iron smallblock. The main problem is the crank flange is in the same spot as a smallblock, but the bore spacing is larger. That means the engine HAS to go farther forward in the car, and sets the weight balance farther forward. It certainly wont help, and this is assuming you cut a LOT of weight to keep things at a relative parity. But I think if you're careful you can make it handle well, but it will always be better with an sbc. Just like it will always handle better with a v6 than an sbc.
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
I would consider the results in a relative manner...are you a top notch road racer? Is the car set up well for racing now? If so, the handling will be negatively affected.
If you have an average car and are an average driver who may hit a track day now and then or drive it on the street for the most part, you will not notice a large difference.
What is the performance level of the BB you plan to install? You can build some pretty stout SBs these days you kow....
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
To counteract the extra weight, you should put on higher rate front springs.
Post this in Suspension and Chassis and I bet SlickTrackGod will reply. Dean seems to be quite knowledgable on chassis setup (not that other aren't it's just that his name comes to mind).
Car: 86 iroc
Engine: 496ci
Transmission: stock t5
Axle/Gears: stock/323 posi
I didn't notice a huge difference. I have an 86 iroc with stock springs. The car seems to handle fine, and is pretty responsive. Even with old economy car tires. I also have cast iron Merlin heads which I believe are 10lbs heavier a piece then stock iron BB heads. I am no professional racer, but for sharp curves on backroads I have no complaints.
Thanks, guys!
Car: 1992 Camaro RS
There's a difference between "handles well" and which is going to handle better. If you just want a car that handles nice then I dont see an issue, but if you're going to do any sort of autocross/track days you may want to think a little more about it.
Either way I can't wait to have a full figure girl in my '89 Camaro, and to be able to unleash all of that horsepower on my budget.
theshackle
Mar 5, 2017 06:37 PM
,and she rides shotgun,without her a BBC won't matter much.
