Difference in cams?
Old Mar 30, 2014 | 05:04 PM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
Difference in cams?
Can someone explain to me the differences in cams? I've youtubed CC503, voodoo 268 cam, LT4 hot cam and a few others. They all seem to (hit) and it might just be me but I really like a car with a cam that hits but I don't know/understand the differences. They all hit hard!
Old Mar 30, 2014 | 07:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Difference in cams?
The majority of cams with a similar grind will all perform relatively the same. You'll only notice the slight difference on an engine dyno.
There's more to a cam grind than just lift and duration. LSA, and valve timing can change how a cam performs with identical lift and duration.
Start with this
http://www.hardtail.com/techtips/camshafts.html
Jake_92RS
Jan 28, 2020 10:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
masonta
Aug 31, 2015 10:14 PM
neekolzun
Aug 24, 2015 04:59 PM
Thirim
Aug 13, 2015 03:09 PM
