Starting a hydraulic street build.
Old Apr 4, 2014 | 08:35 PM
406ciZ28's Avatar
Car: 94 Z28
Engine: 406 sbc
Transmission: Powerglide
Thank you Jim for agreeing to build me a 434. For me it will be the ultimate pump gas hydraulic roller street motor. I first contacted him looking to get a 421 but after discussing what i wanted, he brought up the idea of a 434. It will only be driven as a weekend toy. When i say "street" motor, I mean the wildest I can get and still be reliable and tuned for driving on the street. It will be fuel injected. I am leaning in the direction of a 7730 SD EBL P4 Flash for EFI tuning. Looking to turn it in the 6500 rpm range. I know I can gain more from solid roller and really turn up the rpm's but looking for no maintance and streetable rpm power curve. After parts list is complete and decided upon, short block components will be ordered. Goal is a solid 600 FWHP pump gas street toy. Anyone have any suggestions for cam, pistons, lifters, or anything else I may be missing?
ENGINE
Dart SHP Block
Lunati Pro Series 4.000 Stroke Crank
Crower Billet Stroker Rods 6.0
ATI Super Damper
Pistons ??? (4.155 Bore)
Cam ??? (Looking for something BIG but also street tunable)
Lifters ??? (Hearing Good About Crane)
Crower SS Shaft System
AFR 245 Heads (Too Big?? Maybe Go AFR 235??)
TPIS Miniram & Monoblade TB (Already have the Miniram. Looking to get it Ported. Any recommendations?)
Tranny
T56 (Already Have)
SPEC Stage 3+ Clutch
SPEC Steel Conversion Flywheel (SBC to LT1 T56)
Old Apr 5, 2014 | 08:04 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Re: Starting a hydraulic street build.
Hi. Glad your on your way. If your going hydraulic roller lifter, the cranes are the way to go, but there pricy. You have to use a 5/16 pushrod on afr heads and I used smith brothers .116 wall with a shaft end. Cam I aslo used a crane unit but had them cut it on a billit core which is recommended. The cam was a 110 lobe and we changed it to 112, because of that the duration changed two degrees. Went from 240-242 intake and exhaust went from 246-248. Im using a miniram as most do with these big strokers. I sent you a pm regarding the porting of the unit which you will need to do as they only flow around 305 out of the box. Would recommend an aftermarket efi system as well. If your trans is electronically controller the holley dominator efi is the way to go. Keep us updated. Take care.
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
z28addict8490
Aug 7, 2015 08:48 PM
rsrmoore
Aug 7, 2015 08:44 PM
