Best Vortec Heads for a TBI 377 swap??
Old Apr 29, 2014 | 11:04 AM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
My dad has a 377 he's giving to me. It has Roller Rockers, Cheetah Rods, and other high exspense parts in it. I'm looking to tune it down to around 350hp- 400hp. What would be the best type of Vortec heads for it? I plan on keeping it TBI and running pump gas.
Old Apr 29, 2014 | 05:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It doesn't much matter which factory 350 Vortec head you use (just don't get suckered into 305 Vortec heads).
So, that sort of assumes when you say, "best Vortec heads", you are assuming they would not be factory heads.
Maybe I assume too much.
What heads does it have now? You said it has roller rockers, so it must have heads.
Maybe all you need to do is swap to a milder cam, put the TBI on (you are upgrading the TBI intake manifold, right?), and run it.
Old Apr 29, 2014 | 05:41 PM
Car: 1991 Camaro RS
Re: Best Vortec Heads for a TBI 377 swap??
Right now it has a pair of Dart heads, a beefy roller cam, and dome pistons. It was a 13:1 compression motor my dad used for drag racing. We thought about just changing the pistons and the cam. But the heads are just too large. I don't want to spend the money for aluminum heads, so why not just buy vortec heads?
Old Apr 29, 2014 | 05:55 PM
five7kid's Avatar
Just trying to figure out what you were asking.
What are you planning for an intake manifold? Most any TBI-specific intake would be a severe restriction on a 377.
Old Apr 29, 2014 | 06:45 PM
Car: 1991 Camaro RS
I was going to use a high rise intake with a TBI adapter plate.
Old Apr 29, 2014 | 06:47 PM
five7kid's Avatar
Well, that's good to hear.
Might want to consider this kit:
https://sdparts.com/details/scoggin-...ter/sd8060raag
Old Apr 29, 2014 | 06:56 PM
Car: 1991 Camaro RS
Wow that's a good deal...think with those heads, flat top pistons, and a comp thumpr cam I will get 350hp? I would like to think so.
Old Apr 29, 2014 | 08:12 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
if you go on to comps website they have a cam quest, you can put your info in it and it will help you pick a cam that would work best for you, then you can see what kind of hp and tq it should produce, remember its just on paper not an exact number
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
