Tpi intake on a tbi engine
Old May 7, 2014 | 08:58 PM
Berisford's Avatar
I have a 92 Camaro convertible has a TPI motor. The motor went bad can i take the motor out of the Chevy truck with the TBI set up. Can I take the tbi intake off and put my tpi intake on it will all the intake bolt holes will line up? The motor in my car is a 305 and the motor out of the truck is a 350 will it work for me. Thanks everyone.
Old May 7, 2014 | 09:49 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Tpi intake on a tbi engine
If you swap the heads too, yes. If you don't swap heads, it may not. Check the center bolts on the intake manifold on both. If they are at the same angle on both engines, then it should swap over. Although those truck TBI heads won't work well with the TPI intake setup as far as flow goes. You may have some compatibility issues between the truck engine cam and the camaro's ECM as well.
Old May 8, 2014 | 09:45 AM
Pocket's Avatar
Car: 91 Trans Am
LO5 engines are not vortec, so the intake will bolt up fine. Read over the basic 305 to 350 swap threads
Old May 8, 2014 | 08:20 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I wasn't even considering vortec heads. I was thinking center-bolt vs perimeter-bolt heads.
Old May 8, 2014 | 10:52 PM
Pocket's Avatar
Car: 91 Trans Am
86 was the change over. His 92 TPI will bolt up fine
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
