Can you use 305 tbi carb and manifold on a 350?
Old May 10, 2014 | 07:18 PM
Pactallica's Avatar
Car: 1991 camaro rs 5.0 tbi
Engine: 305 tbi
Axle/Gears: stock
hello everybody I'm new here and just just got my 3rd gen for about a week now and boy I love this car more then anything! I know theres a lot of questions and answers here but I couldn't find what I was looking for....I want to swap my tbi 305 for a 350 (which is really common I know ahha) and I'm wondering can I take the manifold and tbi carb thingy from the 305 and bolt it on the 350 no problem? also I know I have to change the exhaust and tune the computer but is that all to it? Thanks guys.
Old May 10, 2014 | 08:19 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: Can you use 305 tbi carb and manifold on a 350?
thats not 'all' to it, but basically yes your stock intake will 'work' but how well? not sure. You'll also NEED a 350 knock sensor, esc module.
Old May 18, 2014 | 09:21 PM
Pactallica's Avatar
Engine: 305 tbi
Axle/Gears: stock
okay thanks. I guess it would be better to get a new intake manifold for the 350?
Old May 19, 2014 | 06:49 PM
AFAIK there is no difference between a STOCK 305 TBI manifold and a STOCK 350 one.
Which is not to say that you "should" use it; only, that it will work about as well as a STOCK 350 TBI, once the other things, that regulate fuel and timing curves and such, are changed to the ones appropriate to the bigger motor.
Best plan long-run is probably to get a good 4-bbl intake such as a Performer RPM and a TBI adapter. But not "required" to get it working.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
92purpz28
Aug 11, 2015 02:30 PM
