Motor swap question
Old May 24, 2014 | 03:56 PM
Motomonster812's Avatar
Motor swap question
I have a 91 firebird with a 305 5 speed transmission. Me and my dad are wanting to swap to a 350, and build it up to what I want. I'm wondering if the type of 350 block we buy would matter or not? Any advice or tips will help, thanks.
Old May 24, 2014 | 05:11 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Re: Motor swap question
yes it will matter, The flywheel on a 91 is different than a pre 86, pre 86 has a 2 piece rear main seal, where the 91 has a 1 piece rear main seal and uses a different flywheel, the difference in these is the size of the hole in the center of the flywheel, then the intakes are different as well from the pre 86 to the 91, my advice to make things easier would be to buy a 91 or there abouts block so that everything you have now will still work. Really any block you buy will work, just earlier models will cause you to change certain Items you already have!
Old May 24, 2014 | 05:35 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Build it up to where and with what budget?
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
reiderz iroc
Aug 13, 2015 04:57 PM
