3rd gen to LS adapters
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Can anybody tell me what size adapter fittings I need to run the stock 3rd gen oil pressure switch and temp gauge sender? I'm putting them into a 2002 6.0L lq4 motor.
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: 3rd gen to LS adapters
I think this is what you are looking for.
http://www.speedwaymotors.com/Auto-M...ter,20928.html
http://www.speedwaymotors.com/Auto-M...pter,8195.html
Engine: 408 LS
The 6.0 I bought didn't come with an oil pressure switch or temp sending unit. I have both from my tpi motor. That's why I was just going to use adapters.
Car: 1987 Trans Am
Engine: LQ9/L92
I second pocket, especially regarding the CTS. If you're sticking with your factory gauges, you'd need two anyway - one for the gauge and one for the pcm.
As for the oil pressure switch, I ended up using my factory one because I snapped the truck one trying to install it and didn't feel like buying another one.
Engine: 408 LS
I'm going to run the 98 3 wire CTS and run my stock tpi oil pressure switch. Thanks for the replies.
Engine: 408 LS
I ended up using the 3 wire CTS and my factory oil pressure switch with an adapter. I had to drill and tap the adapter from 1/8 npt to 1/4 npt.
As far as the 3 wire CTS, where does each wire go? I know which 3 wires I need to hook up, I just don't know where they need to go on the plug.
1992rs/ss
16
Jan 28, 2016 09:58 PM
