lt1 not charging
Old Aug 5, 2014 | 01:09 PM
nos nut's Avatar
lt1 not charging
i just picked up a 62 bel-air with a lt1 from a 94 trans am. its not charging the battery. it does not have a alt light in dash or a gauge. could this be my problem?
all the wiring from the trans am was pulled and put in the 62. the car runs good other than the alt.
Old Aug 8, 2014 | 02:07 PM
Pocket's Avatar
Car: 91 Trans Am
Re: lt1 not charging
With the engine off, unplug the alt and turn the ign on. You should see around 9v on the single wire
If there is 0v it's not hooked up. Find a 12v ign source and knock down the voltage with a 470ohm resistor
If it's 12v, the excess voltage has burned up the alt. Replace alt and install resistor inline
A light will suffice, but I prefer the resistor as it will long outlast a bulb that's never seen
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
