Chevy 350 Engine swap
Old Oct 21, 2014 | 11:47 AM
Armada95's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: Chevy 350 HSR TPI
Axle/Gears: 3.23 Open
Hello, I'm new here, I'm going to be doing a complete rebuild of a 1980 Chevy 350, casting number 3970010, 4 bolt main, engine suffix code TFH (out of a truck) I'm going to build it into a higher-performance engine (roughly 380-440 hp is my ballpark), and i want to stick it into a Gen 3 Camaro.
I do not have the body at this point in time (the engine is going to be a project for my Automotive Engine Rebuild class) i was wondering how the rest of the drive line will be able to handle the increased HP from this motor, is there a specific trim (RS SS Iroc) i should look for? or just the ones with a V8? im trying to figure out how much money i need to put into the drive line before i get too deep into this project.
I know a lot of factors are involved but i'm just looking for a ballpark, is the stock drive line going to be perfectly fine? or am i going to need to redo it all (It's going to be manual if that helps)
Thanks in Advanced.
Old Oct 21, 2014 | 12:25 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Chevy 350 Engine swap
You can use any third gen car. 4, 6, or 8 cyl car. The same rear end was used in all of the trims, some got lower gears than others, some got posi, etc
The 4 and 6 cyl cars will also need a trans swap as the 4/6cyl trans won't work on a V8
All of the third gens had the stock K member already drilled for 4/6/8 cyl engine mounts.
The stock v8 700r4 auto will handle your power level pretty well.
The T5 5 speed is pretty weak, common 3rd gear failure with 300+ HP.
The rear ends are weak but unless your dead hooking or dumping the clutch at a high rpm it will last.
Old Oct 22, 2014 | 10:03 AM
Armada95's Avatar
Is there a manual Transmission that would handle the power that doesn't require custom mounting, or should i stick with a auto?
Old Oct 22, 2014 | 02:02 PM
Car: 1988 Camaro
Well there is a few manual transmissions that would work but all of them will require some sort of swap/custom work, parts, etc.
The 4th gen T56 6 speed is a common swap and a strong transmission but it's not a bolt up swap. The old M22 4 speeds are strong but again not a bolt in swap.
Old Oct 23, 2014 | 03:50 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
The T5 can survive a long time behind 400hp it all depends on how you drive and how sticky your tires are. Also don't miss 3rd
Other than that a LT1 T56 is your best bet
Old Oct 24, 2014 | 11:35 AM
Armada95's Avatar
Alright cool, thanks for the information guys, i appreciate it, i think i might just stick with the 700R4
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
