350 tpi
Old Nov 27, 2014 | 06:21 PM
camarors2399's Avatar
350 tpi
I'm doing a v6 to v8 swap and I know I have to change the cross member engine mounts but what about the engine side mounts? Thanks in advance.
Old Nov 27, 2014 | 10:43 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Re: 350 tpi
the mounts should already be on your 350 engine. If there not I dont know if the v6 ones would change over.Mesure and see.Probly not though.
Old Nov 27, 2014 | 10:57 PM
Re: 350 tpi
Ok its a l98 so I will check and see thanks for the response
Old Dec 2, 2014 | 10:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The engine side are completely different between V6 & V8.
The chassis side are in a different location, and look close to the same, but V6 & V8 use different parts as well.
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
