350 Carb to 305 TBI system: help
Old Dec 4, 2014 | 02:31 PM
FryeDaddy's Avatar
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
Hey guys, I tried researching into carb to tbi and couldn't find what I want exactly. Simply put I have a fresh rebuilt zz4 crate motor as carb'd that was for my 85' but I'm pulling the string because my 91 rs is such in better shape overall. I've seen that you change the intakes, but like I said earlier the engine has been rebuilt so isn't there a adapter of some sort I could go along to? Also I wanna use my 91 stock 305 wiring stuff tbi on the 350 motor I have, will it be a simple swap? I'm not too savy with wiring stuff, but I can easily find my way around with carb.
Old Dec 4, 2014 | 04:58 PM
static80's Avatar
Car: 89 RS
Engine: 305 TBI
Re: 350 Carb to 305 TBI system: help
You can buy or make an adapter like this
http://www.jegs.com/p/Trans-Dapt/Tra...67206/10002/-1
But I think you'll need to get into tuning to get it to run right.
Also a link to swapping from a 305 to 350 using TBI
https://www.thirdgen.org/forums/tbi/...-350-swap.html
Old Dec 5, 2014 | 07:12 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
why not just keep it carb'd? It's less labor intensive to tuck some wires away than to swap out your intake and go through all that mess.
Old Dec 7, 2014 | 08:12 PM
FryeDaddy's Avatar
Thanks, looks like some reading for me to do. Now does that adapter plate bypass me having to swap intakes?
Old Dec 7, 2014 | 08:15 PM
FryeDaddy's Avatar
Yes I was going that route, but this is my daily and I've heard something about not having to swap intakes. I'm so used to carb yet wanna learn more about fuel injection and I don't like to hack too much on my 91' as well.
Old Dec 9, 2014 | 12:31 AM
FryeDaddy's Avatar
BUMP
Old Dec 9, 2014 | 01:16 AM
static80's Avatar
Car: 89 RS
Engine: 305 TBI
Correct, adapter plate goes from carb style intake manifold to TBI bolt pattern
Also you might want to look into this ECM modification
http://www.dynamicefi.com/EBL_Flash.php
Not too expensive, and you tune it by driving it, and it monitors your o2 sensor and suggests new fuel maps to bring you closer to a proper mixture. I don't have one yet, but it's on list of things to buy.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
92purpz28
Aug 11, 2015 02:30 PM
