882 heads?
Car: 1991 Trans Am
Engine: 350 Crate
Transmission: 700R4 with shift kit
Axle/Gears: 10 bolt 2.73
882 heads?
I recently bought an 0010 block out of a 70 Caprice for $90. The block included 882 heads which will definitely need machined. Now i know as far as performance goes, 882's are very restrictive and prone to cracking in high performance applications. I'm looking to get no more than 350-400hp out of my setup. Correct me if I'm wrong, but I think the stock 0010 setup with 882's were only 250hp.
My question is this; would these 882 heads allow me to get to that magic number in terms of practicality and price? I realize it would take a lot of other upgrades, but I'm just seeing if 882's are cost effective and reliable for the application I am wanting.
I am on a budget, so if these aren't worth using, then I would use them as a core for vortecs down the road. I realize Vortecs are like a religion to some people, but I am on a tight budget. Thanks!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 882 heads?
Throw them away and buy some aftermarket heads. Even cast iron Dart Sportsman heads are a better option but an aluminum head is very affordable.
Car: 1988 Camaro
Re: 882 heads?
882's will not get you there with out alot of port work, valve size increase, and other mods. At that point you could have bought better heads and came out cheaper.
The only production heads that has a shot at 350-400 HP with out a lot of work to them are old 461, 462, etc double hump heads, L98 alum heads, vortec heads
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: 882 heads?
big 76cc's and crack prone. low compression unless you do a stroker or pop-up pistons.
i wouldnt waste a penny on them.
however theyre great for learning how to port, door stops and boat anchors.
Re: 882 heads?
http://www.ebay.com/itm/SBC-Chevy-200cc-Bare-Aluminum-Cylinder-Heads-64cc-Straight-Plug-Small-Block-350-/390487976745?pt=Motors_Car_Truck_Parts_Accessories&hash=item5aeae5ab29&vxp=mtr
use adjustable guildplates as one of the valves is moved .030 from stock , just cant rember if it was the intake or ex side
400 for the pair shipped bare and will cost 2-400 for the rest of the parts depending on which route u go
they flow really good out of the box
Car: 1991 Trans Am
Engine: 350 Crate
Re: 882 heads?
SBC Chevy 200cc Bare Aluminum Cylinder Heads 64cc Straight Plug Small Block 350 | eBay
Car: 1991 Trans Am
Engine: 350 Crate
Re: 882 heads?
I'm really looking into these now. It'll probably be a while, but I have them bookmarked for when the time comes. Thanks a lot man.
Re: 882 heads?
they come in stright and angled plugs as well so make sure u get the ones u need to clear ur headers.
for more info on them look inthe aftermarket product review section for the thread started by me should be on the first or second page lots of pics and info
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
