Please help 305 tbi to carbed 350 swap can't get it to start !!!!!
Old Jan 19, 2015 | 07:21 PM
ChevyMan9987's Avatar
Car: 1988 Camaro sport coupe T-Top
Engine: 350 sbc
Axle/Gears: 4.11
So here's the deal I just finished replacing my head gasket and intake seals as well as valve stems and umbrella seals and lapped my valves got every thing bolted down. I have a new edelbrock 600cfm carb,HEI dizzy,and Mallory fuel pressure regulator with return. I can't seem to get my engine running it cranks and I'm getting fuel and spark but will not fire up. Gas is blowing out of carb and it will backfire out of exhaust dizzy is set TDC I still can't figure out was going on a friend said I may have a bent valve and loosing compression threw carb please can someone shed light on this problem for me. Also my spark plugs are soaked with fuel.
Old Jan 20, 2015 | 05:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like the engine was in the #6 firing position when you put the rotor at the #1 firing position.
In other words, the distributor is installed 180 degrees out.
"TDC" just means the piston is at top dead center. It does not mean the cam is in the compression/firing cycle.
Remember, the crank goes through two revolutions for every revolution of the cam/distributor.
Old Apr 29, 2021 | 12:58 PM
Loren Riether's Avatar
Re: Please help 305 tbi to carbed 350 swap can't get it to start !!!!!
OK.. I switched the fuel lines back to where they are supposed to be.. I dialed in into 47 PSI at the fuel rail. When I crank the car, it makes loud POPS like a backfire from the exhaust but dosent want to turn over and start.. Any Ideas?!?!?!?!
Old Apr 29, 2021 | 01:04 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
I think you fell victim of the infinite scrolling feature and it replied in the wrong thread. I don't see your thread updated.
For the record it is turning over, that's another way of saying it's cranking. It's not firing. Sounds like your distributor isn't lined up correctly.
Old Apr 29, 2021 | 01:10 PM
ahh your right... sorry to hijack the thread...
KnightmareCS
Carburetors
Sep 3, 2012 07:38 AM
Mpperry001
May 14, 2012 12:16 PM
Trevor86TA
May 26, 2004 01:11 PM
mrbnew
May 29, 2002 02:36 PM
BLUE86TPIroc
Mar 5, 2002 05:38 PM
