85 corvette tpi in 91 z28
Hey Guys.
I got a 85 tpi out of a corvette. I got the whole engine and I'm putting it in my 91 z28. If I take everything off my 305 tpi the sensors off the tpi intake and everything will everything just bolt in and work? Since I have it out what would be a good cam to upgrade to?
Any pointers and help that would cause me to get over any trouble of getting it in and running right?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 85 corvette tpi in 91 z28
The TPI out of the corvette is identical to the TPI on your Z28 except the fuel rail comes out on the passenger side instead of the drivers side and it will be MAF while your Z will be a Speed Density set up. There is zero reason to swap them unless yours is broken and unfixable somehow.
Yeah the 305 is crap. It through a rod bearing and he cylinder walls are shot to hell and I don't feel like paying to get it fixed when I could get the same exact motor but a 350 and use my fuel rail. I've been told it just have mounting bolts missing
Car: 1984 Trans Am
It will bolt in just fine. I would actually keep your ECM and sensors from the 91, and just move the manifold and fuel rails over with the new motor and the 350 knock sensor. The only other difference will be a slight tune that you'll have to do with the newer bigger motor since your ECM is expecting a 305.
Car: 1984 Trans Am
The roller motors weren't common in cars until 86. It's fine though to be honest, especially if the motor is broke in. I'm not familar enough with the intakes to answer the question about the bolt holes.
Car: 1984 Trans Am
No difference. If you were going from an 85 motor into a 91 motor you would need a different gear but since your car is newer, no issues.
Getting it for $750. Has 50k original miles on. So I think it's a pretty good deal. Plan on putting in a better cam and servicing the motor before dropping it in. I just need help choosing a good cam
Car: 1984 Trans Am
I would say no. You need a harder gear for the roller cams because of how they're made. If you want, you can swap the gear on the bottom of your distributor to the one from the Corvette if you want.
As for a CAM, I'd look at a Lunati 60102 or 60103 (Those are the old numbers but they still pull up on Lunati's site) or equivilent flat tappet cam. It would be a good place to start anyway. Also remember, when talking to the CAM company, they will ALWAYS say their cam is the best for your application.
Those are for flat tappet cams? Does it require changing anything else, lifters, springs?
Yeah I was thinking of calling summit and asking them what they recommend but I don't want them to recommend a 500 dollar can lol
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You will need to use the flex plate from the 85, the intake manifold and fuel rails , plenum and runners from the 91 and distributor. The small cap hei has a melonized gear and not swap with a hei coil in cap. Contact southbayfuelinjectors to get new 22#hr injectors. If you need a tune send me a pm
A tune, a chip?
Engine: Lb9
Transmission: M20
You can use the small cap distributor as is but will need to grind a u shape for the coil mounting bracket to fit on the 85 intake. The 91 plenum and runners and fuel rail are a direct bolt on.Althogh the 91 had a roller cam and melodized gear it will work on a flat tappet cam. The large cap and small cap shafts are different diameters.
http://parts-catalog.acdelco.com/cat...&parttype=2486
The 85 hei coil in cap will work as well if you install the correct connecter
http://www.ebay.com/itm/Weather-Pack-Delphi-Packard-4-Way-Kit-Flat/110458774508?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D28797%26meid%3D48eb27d2826045f39bae3546ded69141%26pid%3D100033%26rk%3D1%26rkt%3D4%26sd%3D110458774508
The 85 knock sensor is 100 ohms and can work if you keep the 85 esc module and rewire it to the 91 1227730 ecm . The 90-92 uses 3.9K ohm knock sensor. your 305 memcal can be reprogramed to work with the use of your old 305 knock sensor but will not be accurate. To make knock retard function you would need a gm 16151348 code aujp memcal and applicable knock sensor for a 90-92 tpi 350.
Engine: Lb9
Transmission: M20
The manifold will fit, you should instal gaskets between the head and exhaust manifold. The manifold mating surface warps over time and one disturbed doesn't like to seal without a gasket to take up thee never mating surface.
Iroc8t8
May 4, 2026 08:09 PM
ambainb
Apr 25, 2016 09:21 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
Sanjay
Aug 12, 2015 03:41 PM
