Pontiac motor in a 3rd Gen
Old Mar 31, 2015 | 06:23 PM
kester's Avatar
Car: 88 Trans Am & 89 T/A GTA
Engine: 5.7 TPI
Transmission: 700R
Does any have any good resources for parts to install a Pontiac motor in a 3rd gen t/a. Need motor mounts if they are available and headers, etc...
No haters because I'm not doing an LS swap...
Old Mar 31, 2015 | 06:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Pontiac motor in a 3rd Gen
Old Apr 1, 2015 | 09:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a sticky on the topic in the top section of this forum.
Old Apr 4, 2015 | 11:39 PM
kester's Avatar
Engine: 5.7 TPI
Transmission: 700R
Saw the stinky... Those companies must be out of business. Could not find them on line.
Old Apr 5, 2015 | 02:36 AM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
all you should need is a good welder, and something to cut metal and bend pipes ... everything else is just measurements and angles ... motor mounts can be made quick and easy (if you dont mind solid mounts) ... use a bop to chevy trans adapter if you dont want to use bop trans
Old Apr 5, 2015 | 02:50 AM
Barlow8869's Avatar
you could always use plates, for the race look
http://www.jbp-pontiac.com/images/Ti...torplate_b.jpg
Old Apr 5, 2015 | 07:31 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Just use all the same mounting parts that a 2nd gen uses, the 3rdgen engine crossmember is based off the 2nd gen parts and lower control arms are mounted the same in each car.
A 200r4 trans will bolt right up and I have a 200r4 trans Xmember if you need one.
Old Apr 5, 2015 | 12:00 PM
kester's Avatar
Engine: 5.7 TPI
Transmission: 700R
Thank you for your reply. That makes sense. I'm going to use the 700r with an adapter plate. I have a 700r in my 68 LeMans and it works well. Just to ensure I understand. Weld in the kmember mount from a 2nd gen and use 2nd gen mm. Thanks again.
Old Apr 5, 2015 | 03:57 PM
TTOP350's Avatar
Nope, just need the motor mounts for the pontiac motor and bolt them in the 3rdgen car.
Old Apr 5, 2015 | 04:19 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Note second gen Pontiac v8 mounts changed in 75(?). Funny part is my 77 doesn't list any motor mounts even though 76 and 78 does. Go figure.
Old Apr 6, 2015 | 07:19 PM
fteufert's Avatar
Car: 1982 T/A
Engine: 1973 400 Chevy
Transmission: 4 Speed Borg Warner
Axle/Gears: 3:23
1977 to 1979 Pontiac blocks had weird 3 bolt engine mounts, but there are adapters available.
Old Apr 6, 2015 | 07:25 PM
kester's Avatar
Engine: 5.7 TPI
Transmission: 700R
Thank you for the info. So, the way I see it is this swap does not sound to difficult to do. Does anyone have a thought on headers.
Old Apr 6, 2015 | 11:26 PM
TTOP350's Avatar
Use a header for a 78-81 firebird/Camaro with a SBC. Bet they fit like a glove.
Old Apr 7, 2015 | 12:22 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You meant with a Pontiac engine? Pontiac exhaust manifolds exit the heads at an angle that points downwards, unlike SBC that exit almost straight out the side.
Old Apr 7, 2015 | 05:02 AM
kester's Avatar
Engine: 5.7 TPI
Transmission: 700R
Yes with a Pontiac motor.
Old Apr 7, 2015 | 07:38 AM
TTOP350's Avatar
Oh krap, sorry, yes, i ment pontiac engine.
Being tired is bad..
Old Jan 6, 2016 | 09:03 PM
howesbird's Avatar
Car: 1988 Pontiac Firebird
Engine: Pontiac 400
Transmission: 4L80e
I've done this swap successfully
Old Jan 8, 2016 | 05:51 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Yea I'm sure it can be done. I was able to stuff a 521 BBF into my 87 pretty easily. The BBF is one of the largest overall dimension wise production motors. Looked frigin awesome in the car and filled out the engine bay conpletely.
Drop it in and fab up some mounts and your good. Exhaust is easy.
Old Jan 10, 2016 | 02:54 PM
Savage Muffin's Avatar
Could this be done in a 3rd gen camaro?
Old Jan 10, 2016 | 05:46 PM
Car: 87 TA clone
They are the same...
Old Jan 10, 2016 | 08:20 PM
Alright cool thank you. I assumed but, you know what assuming does. Figured it was safer to be 100% sure I've had that swap idea in my head for about 6 months or more. Sorry didn't mean thread jack.
Old Aug 3, 2018 | 10:06 AM
DonutGuard's Avatar
Car: '84 TRANS AM
Engine: 5.7L SBC
Transmission: TH700R4
Axle/Gears: Stock 3.73 Posi
Holy thread resurrection, Batman!
For future reference, I have a '73 block out of a B-Body Catalina. What you're saying is that the engine mounts out of a Second Gen will allow me to make that block a bolt in?
Old Aug 3, 2018 | 11:34 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Yes a 2nd gen firebird
Old Aug 3, 2018 | 11:39 AM
DonutGuard's Avatar
Car: '84 TRANS AM
Engine: 5.7L SBC
Here I thought it was gonna be difficult because of the existence of adapter brackets and what not, when the solution was easy all along.
I tried selling my '84 Trans Am last week and after the guy backed out, I decided I'm just gonna build it like I had intended to before my wagon broke down and became the project car.
Old Aug 3, 2018 | 11:49 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Sometimes stuff works out for you. I looked into doing this swap and lost out on the engine.
Old Feb 27, 2023 | 12:09 PM
wasteland's Avatar
i know thi sis old but where you able to run headers if so what headers di dyou use
Old May 10, 2024 | 08:41 PM
wasteland's Avatar
I know this is old but did u have to use a ram air adapter for your oil filter housing or were u able to use a stubby oil filter with factory housing
1992rs/ss
Jan 31, 2025 05:10 PM
jhawkeye
May 25, 2022 06:33 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
reiderz iroc
Aug 13, 2015 04:57 PM
