Young buck, BROKE! Most viable v8 to swap?
Old May 10, 2024 | 01:44 AM
Camaro1992RS's Avatar
Car: 1991 Camaro
Engine: 3.1L
Like the title says, I’m not rich like the rest of us right, but my goal is to as cheaply as possible v8 swap my very slow 3.1 v6 in my 92 RS. I think I want around 250-300 horsepower and also want to be mindful of gas guzzling! (I’ve heard corroborated motors tend to use a lot of juice?) What am I looking for a CSB 350? or something else… also what else should I expect to upgrade, rear differential, transmission ? what else ?
What would you do?
very new to auto mechanic stuff but so far like it and wanna get my hands dirty for something I’ll have pride in!
Live in SA Tx if you have an old motor or parts!!!
3.1L v6 -> ??? V8
Old May 10, 2024 | 07:02 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Young buck, BROKE! Most viable v8 to swap?
What is your budget? Cheap is relative. You may be better off just buying a V8 thirdgen if you don't have the means or experience mechanically.
Old May 10, 2024 | 07:24 AM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Just let me preface this by saying you post is more often found on FB groups than here, as this forum generally prides itself on sanity, IMO.
It's silly and ridiculously expensive to swap a V8 into a V6 car. If you do your research, you can easily get the horsepower you're looking for out of that V6. Or, sell the V6 car and buy a V8 car.
Old May 10, 2024 | 09:17 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Old May 10, 2024 | 10:16 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
It can be done if you locate a v8 "parts car" to take all the needed parts from-a '90-92 v8 RS would be good Once v8 conversion is all working like it should,then engine can be upgraded to get to the(easy) HP goal you have listed.
Old May 10, 2024 | 10:28 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Non-stock engine swaps are $5k, the only way to make it cheaper is to absolutely reuse everything from another running car and replace only broken stock parts with stock parts.
That being said, you can do the non-stock swap investing $500 every month in the new bundle of parts you need and then save up while you're making progress on the swap over the course of a year.
Old May 10, 2024 | 12:09 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Originally Posted by Camero1992RS
What would you do?
Drive the car as-is until I:
*Had about $4000-5000 cash saved up.
*Had some hands-on experience working on cars (minor repairs, maintenance, etc).
Old May 10, 2024 | 12:12 PM
Roorancher's Avatar
Engine: 5.0/5.7 LT1
And buy a V8 roller....
Much easier and less work than starting with a V6.
Old May 10, 2024 | 12:38 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
In all honesty, If you are really that broke, you shouldn't spend a dime on the 3rd gen unless its broken and you need it to get to work.
Old May 10, 2024 | 03:37 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
^^^^This is probably the most practical approach, since all the other systems besides the engine and transmission in a 6- cylinder 3rd gen will require upgrading. It makes better sense to start out with a car that already had a V8 from the factory.
The only possible exception, IMO, would be if the 6- banger car was absolutely pristine, inside and out. And even at that, plan to bring a big bag of $$$.
Old May 10, 2024 | 08:45 PM
Car: 1991 Camaro
Engine: 3.1L
NOOO my father has told me this … but I don’t wanna do that I want this bb to be something cool I got the pride and elbow grease into… : / like 2-3k building the motor and keeping the v6 to daily until then is my goal 🤔 reasonable ?? Ofc tranny as well but piece by piece.
Old May 10, 2024 | 08:58 PM
Car: 1991 Camaro
Engine: 3.1L
Im delusional I get it… what’s new, aren’t we all…
Do you actually know I can get 250-300+ HP from a 3.1 v6 (IVE GOT A LOT OF NO’S) is this realistic without something failing or exploding. one guy said said yes, but with a turbo kit. So what’s actually up 🤔
Old May 10, 2024 | 09:25 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Are we all being Punk'd?
Old May 10, 2024 | 10:24 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Yeah you could probably throw down 250 with a turbo. It'll still cost you 5k and you might as well be doing a turbo 350 so when you break stuff it'll be proper violent and explodey.
Old May 11, 2024 | 01:04 AM
Car: 1991 Camaro
Engine: 3.1L
Yes. Your whole life is a lie. End it b4 it’s to late… 😳😨
Old May 11, 2024 | 01:05 AM
Car: 1991 Camaro
Engine: 3.1L
Originally Posted by Komet
https://youtu.be/VYCQen9CfXQ?si=62soBQo9jVPTQtLH
😂👍 I’ll consider
Old May 11, 2024 | 01:25 AM
Airwolfe's Avatar
Are you really 18?
You're not one of the old school TGO forum regulars that opened a new account yesterday just to mess with us?
Do you know that your car is a 1992 Camaro RS and not a 1992 Camero RS?
Old May 11, 2024 | 09:44 AM
OrangeBird's Avatar
Car: 1989 Firebird
Yep. I had a big ol long post all typed up, but wisely decided to slowly back on out, and close the door behind me....
Old May 12, 2024 | 10:07 AM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
It CAN be done cheaply if you put in the effort. Last year I bought two 3/4 ton work vans from a local heating and cooling company for 1k. They get too many miles and get shoved to the back lot. Both had over 200k miles. I brought a battery, air tank, and fresh gas, and after some tinkering was able to drive each one home. After basic tune-ups, and fluid changes They both ran excellent with no noises or issues. My total investment before I sold them was around $1900. That was TWO LS style engines, TWO 4L80 trans, and all accessories, wiring, ecu, etc needed for swapping into something else......in good RUNNING condition!! Look around, make a deal on A COMPLETE VEHICLE, and swap everything. Including a basic overhaul, mounts, headers, etc I think you could do it ALL for less than 4K.
Old May 14, 2024 | 12:53 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
If you're broke I'd look at something different then. The 3rd gen tax is gonna make you homeless
Old May 14, 2024 | 06:29 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Junkyards are full of these and they make for an easy swap and unlimited parts availability
Old May 14, 2024 | 06:55 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
i don't think i've ever seen a corvette in a junkyard around me.
Old May 14, 2024 | 09:34 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Just drive the sh** out of it and move on!
Old May 14, 2024 | 11:00 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You will be money ahead if you find a similar car with a V8.
Regarding V6 to V8, I think the easiest thing to do would be a carbureted engine. Your fuel system will support it, just need a proper fuel pressure regulator. You'll need the V8 engine and transmission, engine mounts, accessories with brackets and belts, and exhaust. Wiring will be minimal with a carbureted engine. May need V8 front springs to prevent car from squatting too much. Watch coolant temps, may or may not need a radiator / fan upgrade.
Word of advice... at your age you will be interested in this car now and interested in another 6 months from now. I would not dump money into this car, your interests will change quickly as your income changes. You'll be through with this car and on to another before you know it.
Old May 14, 2024 | 01:45 PM
LOL.......laden with sarcasm!
Clintandthebird
Apr 13, 2016 07:13 PM
chev496
Feb 4, 2004 07:12 PM
Camarojohn82
Mar 2, 2003 07:04 PM
AgentD
Mar 29, 2002 06:23 PM
